View Full Version : 1969 Chevy NOVA 355 Vortech, 12 bolt, etc $42,000 NEG
danielburko
04-20-2017, 10:32 AM
Listing this for a friend who is torn to sell it. You WILL NOT find a cleaner 1969 Nova anywhere. A lot of time has been spend on this car of the years and years of ownership. All of the bugs have been worked out and it can be driven across the country.
IF THERE ARE ANY QUESTIONS PLEASE SEND THEM TO ME AND WILL GET AN ANSWER FOR YOU PROMPTLY.
The car HAS NOT been raced, but easily can be taken to a drag track or auto cross setup with zero worries. Truth is, its only driven on nice days and spends a good amount of its life in a garage under a cover with a battery tender on it. It does get driven once a month around the block to keep everything lubricated so there are no issues as well.
Here is whats in the car:
ENGINE
ZZ4 355 GM CRATE MOTOR
BLACK RPM AIR GAP INTAKE EDELBROCK
VORTECH SUPER CHARGER V-3
TAIL 50MM BLOW OFF VALVE ( WHITE,YELLOW,BLACK,GREEN-SPRINGS)
QUICK FUEL Q-750 BAN BLOW THRU CARB
MSD PRO BILLET DISTRIBUTOR
AEROMOTIVE FUEL PRESSURE REGULATOR
AEROMOTIVE ELECTRIC FUEL PUMP RED ANODIZED
AEROMOTIVE FUEL FILTER
ALUMINUM RADIATOR
LOW BOY HI PERFORMANCE ELECTRIC FAN
OPTIMA YELLOW TOP BATTERY
POWER MASTER XS TORQUE STARTER
TRANSMISSION
AUTO / MANUAL
4L60E OVER DRIVE FREDDIE BROWN HI PERFORMANCE STREET TRANS
2500 - 2700 STALL CONVERTOR
TCI HAND HELD COMPUTER EZ - TCU
TCI WIRING HARNESS
MOMENTARY SWITCHES 1. UP SHIFT 2. DOWN SHIFT 3. STALL CONVERT CONTROLLER
PERFORMANCE MODE SWITCH
ECONOMY MODE SWITCH
B & M BLACK DIAMOND SHIFTER CARBON FIBER RATCHET
B & M HI TEK TRANS COOLING SYSTEM AND FAN
INTERIOR
CUSTOM SEATS
CUSTOM DOOR PANELS
CUSTOM LEATHER BILLET FESLER STEERING WHEEL
NEW CARPET
BLACK COBOLT BLUE LED GAUGES - OIL - TEMP - VOLTS - CLOCK -
DIGITAL ELECTRIC TACH GAUGE WITH MEMORY SETTINGS MULTI COLORS
DIGITAL AEM AIR / FUEL GAUGE
SPORT COMP BOOST GAUGE
PIONEER STERO SYSTEM / BLUE TOOTH /USB /FLASH DRIVE
KICK PANEL SPEAKERS IN FRONT 6 X 9 IN BACK
FLAMING RIVER STEERING COLUM
BLUE LED COURTESY LIGHTS
NEW DASH WIRING HARNESS
PAINT
SPIES HECKER JET BLACK 2003
SPIES HECKER CLEAR 8035
CUSTOM BLACKED OUT LIGHTS - TRIM - EMBELMS -BLACK
CUSTOM FAB SANDED AND PREPPED BUMPERS - BLACK
LIGHTS
DIGI TAILS LED LIGHT KIT ALL AROUND
BLUE HALO HEADLIGHT / HID LIGHT KIT
PAINLESS SUB FUSE PANEL
EXHAUST
CUSTOM 3 '' PIPES MANDREL BENT
CUSTOM X PIPE
BORLA MUFFLERS 3 '' XR1
HOOKER HEADERS
REAR
12 BOLT POWDER COATED
EATON POSI UNIT
373 RICHMOND GEARS
MOSER 31 SPLINE AXLES
C CLIP ELIMINATORS
CAST ALUMINUM DIFFERENTIAL COVER
SHOCK RELOCATION - CHROME MOLY BAR
SUSPENSION
NEW BODY BUSHINGS ALL AROUND
1 3/8 SWAY BAR
QA1 ADJUSTABLE COIL OVERS
SUB FRAME CONNECTORS
CAL TRACS
MULTI LEAF SPRINGS
QA1 ADJUSTABLE REAR SHOCKS
WHEELS
CUSTOM BONSPEED POWDER COATED
FRONT 18 X 7 26 BY 8.00 R18 MICKEY THOMPSON SPORTSMAN
REAR 18 X 9 28 BY 10.00 R18 MICKEY THOMPSON SPORTSMAN
POWDER COATED LUG NUTS BLACK
POWDER COATED CENTER CAPS
12 POINT ARP NUTS AND BOLTS POWDER COATED 30 PER WHEEL
139572 139573139574139575139576139577139578
