View Full Version : Anybody got a PPG catalog?
Damn True
11-20-2005, 11:05 PM
I thought I'd found the paint code for one of the paints I plan to use on my Camaro. It is the finish used on the Ducati Moster Dark. The number I found however is a Ducati part number, not the PPG paint code.
Can anyone find this code for me?
The paint is made by PPG.
I can't remember what the finish on the duc looks like, but I did find this. Are any of these the one?
PAINT MANUFACTURER – PPG COLOR / PAINT CODE PPG / Metallic Black / 291.500 PPG / Ducati Red / 473.101 PPG / Ducati Yellow / 473.201 PPG / Metallic Grey / 291.601 PPG / Ducati Metallic Blue / 291.800 PPG / Dark (Senna) Gray/ PPG 0017 PPG / Gray Steel / 223.647 PPG / Titanium / 291.600
or...
Nero Dark Ducati
PPG 291.501
*I think the last one is it*
SPEEDZONE
11-23-2005, 06:05 PM
I have a paint shop for cars and motorcycles. I had that color custom matched and formulated and I can get it for you on Fr if you like. Its a bc/cc. I gotta say, achieving a uniform level of "flatness" with the special clear (DCU2060) is a b!TCH.
Damn True
11-25-2005, 08:40 PM
Good info in light of the fact that I'm going to be using on the entire top of the car (hood, roof and decklid).
SPEEDZONE
11-26-2005, 11:21 AM
as long as you spray all the areas at the same time, with the same batch of mixed and ready to spray clear, you will be ok. Its when you try to spray the panels at different times with different batches of the clear mixed up, is when you run into problems. The 2060 is mixed with different ratios of regular clear (2042, for example) to achieve the desired degree of flattness/gloss, and just a fraction of an ounce + - with the clear and hardner will cause it to have a different look than your previous batch. Hope this helps
Damn True
01-19-2006, 11:55 PM
Ok, how about a paint code for Subaru World Rally Blue Pearl?
https://static1.pt-content.com/images/pt/2006/01/sti_on_dyno-1.jpg
Damn True
01-24-2006, 10:04 AM
Nuthin on the blue?
Anyone?
Damn True
02-08-2006, 06:32 PM
Ttt
