View Full Version : LS1 70 chevrolet swap oil pan questions
davisgsxr06
04-09-2017, 06:21 PM
Ok, done several first gen swaps, new to this one, on Ls1 swap in 70 chevelle, what oil on is everyone using for a swap. Have 5.7 out our 99 SS will the f body oil pan work or not.. Thanks in advance...
raustinss
04-10-2017, 10:34 AM
Pretty sure the best fitting pan is from holley right now ...I believe they have two models . The biggest issue with a bodies with ls swaps is grease fittings hitting the old pan , some people swap to a 90 degree fitting and they're fine . Depending on the accessories, if it has a low mount passenger side ac compressor you may want or need to clearance the frame . Hope this helps .. Let us know how things work out and toss some pictures up too
csouth
04-10-2017, 11:38 AM
Holley, Mast and Autokraft. If you have the F-Body pan already, you can use that. You can move the motor forward more with the Autokraft pan. I had the F body pan and cracked it, my fault. Replaced it with the Autokraft.
Rucumn
04-10-2017, 01:27 PM
Holley 302-2
andrewb70
04-10-2017, 01:34 PM
Holley 302-2
Along with the Holley mounts. They have everything for this swap and it was all designed to work together.
davisgsxr06
04-11-2017, 08:18 PM
Thanks for all your responses, I do have the F-body pan on it still & going to run high mount ac on passenger side head... What mounts do I need to use if I use the f-body pan that's already on engine... Motor came out of 2000 ss... Which the alt is low mount on drivers side. Will I have to notch frame for that? Thanks in advance, will get some pics posted soon, 14 hour days gettin best of me...��
