View Full Version : Hubcentric spacers
Shawn01754
03-27-2017, 03:56 PM
Hi, question for you guys. I got my custom wheels and as I was mocking up, I realized they wernt hubcentric to my hubs. The front i have the c-5 and the rear is the gm 12 bolt with kore 3, c-5. Should i get the hubcentric adapters? What do you generally do. The lug nuts seem really good. Thanks
TheJDMan
03-27-2017, 04:32 PM
Hubcentric is nice but not critical. So long as the wheel and hub are the same bolt pattern the lugs will center the wheels.
Schwartz Performance
03-27-2017, 05:01 PM
What he said ^^
Also, depending on your pad thickness beyond the lug nut taper, you could use a shank lug nut. They have about 1/4" long shank which can assist with centering.
Shawn01754
03-27-2017, 05:28 PM
What he said ^^
Oh. Thats cool. Could you send a link? Thanks!
csouth
03-28-2017, 05:27 AM
They sell them here if you still want them...
http://www.motorsport-tech.com/wheel_spacers.html
dhutton
03-28-2017, 05:48 AM
Just search for ET ultra lug nuts on Summit etc.
Don
Skip Fix
04-01-2017, 07:37 AM
I will disagree it all depend on the wheel and lugnut combination being designed for lugcentric.
Example my Trans Am snowflake 15x8 are hubcenteric(not the repop 17" ones). The factory lug nut is only .710-.720 OD lugnut hole in wheels 0.750. Use an aftermarket lugnut(because you jumped to 1/2 studs) most are only .680. If there is no correct length or correct diameter pilot to locate the wheel to be hubcentric there is a lot of room for the wheel to be offset. Found this out when I had Moser axles that have a short pilot that barely sticks out of the rear rotor to use some extra tires/wheels to roll the car around the shop with .680 lugnuts.
Dutchman can make a linger brake pilot to help with hubcentric issues-Moser will not.
You can find all different OD/ID rings out there. Most GM hubs are 2.78"
andrewb70
04-01-2017, 04:10 PM
Companies also make hub centric adapter rings that will center the wheel on the hub as you tighten down with the lug nuts.
