View Full Version : 2000 tahoe limited frame swap questions
Teddy
03-25-2017, 10:36 AM
Hey guys i have a 2000 tahoe limited that i want to put on the frame of a 2008 chevy avalanche. The avalanche body is wrecked but the frame, engine, trans, and brakes are all intact. Would this swap work? Any advice would help
raustinss
03-25-2017, 12:38 PM
Although they do share lots of parts I'm going to say no do to the wheelbase length , you will need to shrink the frame and wheelbase by 14" .... Once you do that then it would be the body mounts ....etc etc . Might just be easier to remove the engine, trans, suspension etc and swap those over being as they're damn near perfect exchanges
130fe
03-25-2017, 04:55 PM
Isn't the avalanche and suburban the same chassis?
raustinss
03-26-2017, 05:31 AM
Nope ... at least according to Wikipedia lol, regardless the wheelbase is still off quite a bit . It would be way easier to swap the good drive train over and suspension and we know the parts are a direct fit
Randy67
03-26-2017, 04:39 PM
The Tahoe is shorter than the Avalanche like Ryan said. Now the Suburban and Avalanche are the same chassis and length. I would just swap the driveline from the Avalanche to the Tahoe, much easier than the body.
Teddy
03-27-2017, 05:27 AM
What about brakes because drums suck. Is there a kit i could buy for a rear disc conversion?
raustinss
03-27-2017, 08:12 AM
Sure ..lots ...all depends on your wallet thickness
Teddy
03-27-2017, 08:20 AM
What parts from the avalanche fit other than the motor and trans?
raustinss
03-27-2017, 01:33 PM
Ummm pretty much everything lol... essentially the same vehicle just longer
Teddy
03-27-2017, 03:05 PM
What year would yall recommend i get my parts from?
raustinss
03-27-2017, 06:37 PM
Now I'm confused.... Thought you had both vehicles
Teddy
03-27-2017, 07:48 PM
What will i gain by swaping the suspension and can i also swap the differentials so i can have disc brakes all around and 6 lug rims?
raustinss
03-28-2017, 05:17 AM
Well swap the suspension if one is better than the other ...otherwise I'd say leave it alone.. Swapping the diffs is a bolt in affair ,so yes you could keep the disc brakes
Teddy
03-28-2017, 02:31 PM
Would that be the best way to get disc brakes in the rear without buying an expensive kit?
raustinss
03-28-2017, 05:34 PM
Big time ...you already own them don't you ?
Teddy
03-28-2017, 05:36 PM
Yeah thanks alot for your help i'll be working on my truck this weekend ✌
raustinss
03-29-2017, 08:14 AM
Yeah for sure ..good luck hope all works out, post some pictures if you have the time
