View Full Version : 700 HP 1969 Camaro 540 BBC “Do-Under” Gets All New Underpinnings At V8 Speed & Resto
oestek
03-21-2017, 06:40 PM
Some say these cars are never finished, and that holds true especially when a modified car changes hands. In this case, our customer purchased this killer 1969 Chevrolet Camaro as a freshly completed Pro-Touring machine complete with a slick silver paint job and a very cool red leather interior, but the 700+ HP 540-cube Shafiroff big block Chevy and 6-speed T-56 Magnum transmission are a bit much for the otherwise stock suspension. The huge torque easily overpowers the rear tires, and the handling isn’t up to the expectations of the owner. So, the car was sent to the V8 Speed & Resto Shop so our crew could take the suspension, rear axle, wheels, tires, brakes, and a few other areas of the car to the next level. The big challenge - installing a complete Detroit Speed QUADRALink rear suspension and front subframe, wheel tubs, Currie Enterprises rear axle, Forgeline wheels, Toyo Tires, Holley EFI, and more without damaging the beautiful silver paint or messing up the body panel fit. After all, something that looks this good should have the moves to match!
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021816_0002JPG-1.jpg
oestek
03-21-2017, 06:42 PM
Like every car that arrives in the V8 Speed & Resto Shop, and our first task is always to perform a thorough inspection. We prepare a 10 page inspection form which gives us a good reference point on how the vehicle arrived in the shop, and provides the customer for an overview on the car’s shape. We also take a substantial amount of photographs documenting the condition, which provide a reference point not only of how things were put together, but also if there were any nicks or scratches or blemishes on the car when it arrived.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0063JPG-1.jpg
This is a really nice car, but we did find a few things to address here and there, like crushed fuel lines and the occasional chip & scratch.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021616_0098JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0083JPG-1.jpg
Some of the wiring and plumbing would benefit from some detailing and cleaner routing.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0081JPG-1.jpg
540 cubes of rich-running big block fury!
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0091JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0090JPG-1.jpg
Short exhaust misery… this one was loud and the lack of tips made a big mess when the car was idling.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0073JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_021516_0072JPG-1.jpg
Our customer had a pretty solid plan for what he wanted done to this car, so we put the part list together and began to order parts.
oestek
03-21-2017, 06:45 PM
This was kind of fun… an AN fitting installed with electrical tape. On a high pressure fuel line. Not something you want to have, as this thing could have let go and sprayed fuel all over the hot engine causing a big fire.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0040JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0041JPG-1.jpg
The plan called for installing a Detroit beat QUADRALink rear suspension which involves cutting the floor, so the interior needed to come out. The rear seat would also need to be narrowed as we are installing larger wheel tubs.
Our team carefully disassembled the rich red leather custom interior and we carefully wrapped, labeled, and stored in these pieces to keep them safe.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_022916_0007JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_022916_0015JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_022916_0016JPG-1.jpg
- - - Updated - - -
This car had a layer of some type of foam insulation that was glued to the back of the carpet, so it made quite a mess coming out.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030116_0021JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030116_0023JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030116_0031JPG-1.jpg
Removing the custom upholstered trunk mat…
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030116_0037JPG-1.jpg
...revealed more of the sticky foam sound deadener.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0044JPG-1.jpg
Fuel tank and exhaust out of the way…
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0045JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0046JPG-1.jpg
oestek
03-21-2017, 06:46 PM
Most of the work was to be done on the bottom side of the car, so we wrapped the entire outside of the car with several layers of protective film and weld and 3M spark paper to keep it from getting damaged during the process. We also wrapped the dashboard and wrapped headliner to protect it from stray sparks. This paper isn’t cheap, but it’s far cheaper than paint repairs on a nice car!
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0038JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030216_0047JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_030716_0002JPG-1.jpg
The car was rolled into the fabrication center where Adam began the chassis disassembly process.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0004JPG-1.jpg
He unbolted the stock rear leaf spring suspension, brakes, and drives haft and slid the 12 bolt rear axle out of the way. We had ordered a Currie Enterprises 9+ rear axle assembly and to take it’s place, but the first task was to install the QUADRALink brackets and narrow the rear frame rails.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0005JPG-1.jpg
oestek
03-21-2017, 06:48 PM
Soon, the cutting begins on the inner wheel tubs to make room for the Detroit Speed mini-tubs. The rear frame rails will be narrowed as well.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0002JPG-1.jpg
We did not anticipate touching the outer wheel wells, but removing the undercoating revealed some previous repairwork that made us adjust the plan. Typically, we would have removed and replaced the outer tub upon this discovery, but that would require repainting the quarter panel where it meets and welds to the wheel house.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0006JPG-1.jpg
This second outer seam is not normally present on these cars.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0008JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032316_0013JPG-1.jpg
oestek
03-21-2017, 06:51 PM
The driver side had a similar repair.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032416_0002JPG-1.jpg
Pinching the frame rail for the Detroit Speed tubs to fit.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0004JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0001JPG-1.jpg
After cutting out the previous repair, it was determined that a replacement strip should be welded in place of the old repair. This would preserve the outer wheel house, and this time, it would be metal finished to blend in and the repair would be undetectable.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0006JPG-1.jpg
- - - Updated - - -
Forming the new strip
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0005JPG-1.jpg
The new piece was made on the shrinker / stretcher to bend a 90 degree piece around to match the wheel tub shape.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0008JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_032916_0010JPG-1.jpg
The new strip was resistance spot-welded to the original welding flange on the new DSE deep tub, and then welded to the original outer tub with a series of tack welds all the way around.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_033016_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_033016_0004JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_033016_0006JPG-1.jpg
Here, you can also see the finished narrowed frame rail.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_033016_0008JPG-1.jpg
After grinding, the seam is invisible, but the original wheel tub seam is present.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040116_0007JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040116_0006JPG-1.jpg
The trunk floor was recessed to accommodate the wider tub.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040116_0008JPG-1.jpg
oestek
03-21-2017, 06:53 PM
Next, the process was repeated on the driver side.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040116_0010JPG-1.jpg
Some filler was found in the trunk floor, so the area was investigated to assess structural integrity.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040716_0003JPG-1.jpg
After some cleaning and grinding, some corrosion holes were uncovered.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0001JPG-1.jpg
The cabin floor was marked for trimming to accommodate the wider wheel tub.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040716_0007JPG-1.jpg
The rusty area of the trunk and cabin floor was cut out.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_040716_0012JPG-1.jpg
- - - Updated - - -
The frame rail was narrowed, and the wide Detroit Speed wheel inner wheel tub was installed.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0004JPG-1.jpg
The HTP resistance spot welder is used where the electrodes can access the panels, and the remaining welds are traditional plug-style welds.
More body filler was found in the trunk floor in the location where the new rear crossmember will be installed. The crew hoped that this was confined to the area of the trunk floor that would be cut out.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0006JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0008JPG-1.jpg
oestek
03-21-2017, 06:56 PM
The white line represents the area that will be removed for the upper crossmember installation.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0010JPG-1.jpg
More filler deeper into the trunk floor. The decision on the repair was posed to the customer, and Adam proceeded to install the DSE crossmember.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0011JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_a_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_a_0002JPG-1.jpg
In the passenger cabin, the DSE upper control arm mount pockets were installed in the rear passenger seat floor.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_a_0009JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_a_0010JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0014JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041816_0019JPG-1.jpg
- - - Updated - - -
The rear seat will require some modifications to accommodate the wider tubs and control arm mount pockets.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041916_0020JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041916_0021JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0031JPG-1.jpg
Meanwhile, a new rear axle assembly was finished. The housing is a narrowed Currie unit that has been fixtured in preparation for welding the Detroit Speed brackets in place.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_041916_0022JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0026JPG-1.jpg
oestek
03-21-2017, 07:00 PM
The center section is a Currie 9+ nodular iron unit, stuffed with a Detroit TruTrac limited slip differential and 3.70:1 gears, with 31 spline Currie axles.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0028JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0029JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0030JPG-1.jpg
Metalwork nearly complete on driver side wheel tub.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042016_0032JPG-1.jpg
After considering the filler covering rust repairs in the trunk, it was determined a new trunk center pan would be the best course of action. The section was removed.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042616_0017JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042816_0009JPG-1.jpg
- - - Updated - - -
The new center was ordered from Classic Industries and installed. The perimeter was TIG welded with an HTP Invertig unit, and the center supports were resistance spot welded using an HTP VersaSpot 7000.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042816_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042816_0002JPG-1.jpg
The leading edge was MIG welded to the crossmember per the Detroit Speed instructions.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042816_0003JPG-1.jpg
The perimeter was metalfinished to blend with the trunk floor.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042816_0005JPG-1.jpg
The increased wheel tub size and narrowed frame rails are more visible from under the car.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_050416_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_050516_0002JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_050516_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_050516_0005JPG-1.jpg
The rear axle assembly was lifted in place to determine the location for the upper shock mounts.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042916_0015JPG-1.jpg
- - - Updated - - -
The new Baer brake rotors are test fitted as well.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042916_0016JPG-1.jpg
The wheel was installed to locate the axle in the wheeltub.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_042916_0019JPG-1.jpg
Rear panhard mount installed.
https://static1.pt-content.com/images/pt/2017/03/1969_Camaro_LA_050616_0012JPG-1.jpg
Mach1_Ron
03-22-2017, 04:33 AM
Very Nice Work.....
oestek
03-22-2017, 05:11 AM
Very Nice Work.....
Thank you Ron!
slimjim
03-22-2017, 05:53 AM
I love the preparation and protection steps you take prior
oestek
03-22-2017, 05:55 AM
Thanks James... the time and materials to protect is far less than a repaint!
Fahrenschnell
03-22-2017, 07:13 AM
Love the detailed Pics and Info in your threads. Keep it up. And how about a video of that big block burbling when you finish.
oestek
03-22-2017, 07:34 AM
Thank you! And yes, there will be video... and not just burbling! (evil laugh... )
rohrt
03-22-2017, 08:21 AM
Good stuff.
OLDFLM
03-22-2017, 12:36 PM
Love your projects Kev! Keep the pics comin'!
oestek
04-27-2017, 08:08 AM
Good stuff.
Thanks guys!
- - - Updated - - -
At this point, we turned attention to the front of the car. The stock GM Camaro subframe was going to go in favor of a Detroit Speed Hydroformed subframe. We elected to drop the stock subframe complete with 540 cube V8 with the front sheetmetal in place, with the goal of not having to remove, reinstall, and realign the panels if we didn’t have to.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0001JPG-1.jpg
The body was placed on the lift and protected with spark paper. All the fluids were drained from the engine, the wiring harnesses were disconnected, brake lines separated, coolant hoses pulled, the A/C charge was evacuated and the lines disconnected. The body bolts were loosened from the subframe, and the car was carefully raised up off the subframe.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0005JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0011JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0012JPG-1.jpg
oestek
04-27-2017, 08:13 AM
In the doghouse…
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0015JPG-1.jpg
We’ll clean up the big harness hole with no grommet, and sheet metal screws in the shifter hole / transmission tunnel.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_050916_0020JPG-1.jpg
- - - Updated - - -
Also discovered that the pilot bearing had eaten itself.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051016_0025JPG-1.jpg
The starter was a bit hungry as well, as it ate some flywheel teeth.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051016_0028JPG-1.jpg
The 540 on the stand, ready for a re-gasketing to stop some leaks.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051016_0042JPG-1.jpg
oestek
04-27-2017, 08:15 AM
The metal crew repaired the holes in the floor, and the entire pan was scuffed for new epoxy and coatings.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0004JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0005JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0006JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0007JPG-1.jpg
Bottom side cleaned and seam sealed.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0010JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051316_0014JPG-1.jpg
- - - Updated - - -
Fresh repaint.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051416_0022JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051416_0031JPG-1.jpg
New trunk floor and suspension mounts painted.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051416_0035JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051416_0037JPG-1.jpg
JustJohn
04-27-2017, 10:44 AM
Amazing work you do without ever touching the top side paint.
oestek
04-29-2017, 01:42 PM
Thanks John, this car had beautiful paint on top, so we didn't want to mess that up!
- - - Updated - - -
The Currie 9+ rear axle assembly was cleaned and prepped for paint. After a good bath with wax & grease remover, the crew taped off the threads and applied several coats of Axalta epoxy primer.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0010JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0011JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0012JPG-1.jpg
The axles were treated to the same process.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0013JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0015JPG-1.jpg
oestek
04-29-2017, 01:44 PM
Mmm, drab green epoxy!
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0016JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0017JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0018JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052016_0020JPG-1.jpg
- - - Updated - - -
Next, the housing and axles were treated to a bath in Imron industrial urethane. That’s more like it!
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052316_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052316_0002JPG-1.jpg
oestek
04-29-2017, 02:07 PM
The engine was next to receive some attention. This monster ran hard, but had developed a few leaks in addition to the clutch / flywheel issues. The hood clearance was tight, and the owner requested a different intake and EFI system to be installed as we re-gasketed the engine.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051016_0043JPG-1.jpg
Intake removed and gasket surfaces cleaned and ready for new Holley intake.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051616_0010JPG-1.jpg
“Big” roller cam, ported Dart heads, lots of power to be made here.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051616_0012JPG-1.jpg
- - - Updated - - -
Jet-Hot coated Holley EFI multi-point intake manifold. This is part of a Holley HP big block Chevy package.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051616_0017JPG-1.jpg
The intake was upgraded with some new squirters from Injector Dynamics.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0019JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0020JPG-1.jpg
Here, the billet Holley throttle body, fuel rails, sensors, stat housing, and MSD distributor are in place.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0021JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0026JPG-1.jpg
- - - Updated - - -
We elected to swap the hard line for a braided crossover -6 hose for better flow, and a blacker look.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0033JPG-1.jpg
A quick flip to replace a leaky pan gasket and to have a look-see at the bottom end… what’s that on the pickup screen?
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051916_0004JPG-1.jpg
Someone went a little strong with the silicone on assembly, and remnants were stuck to the oil pump pickup screen.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051916_0001JPG-1.jpg
We made sure to scrape all the excess goo from the pan rails, and used far less on reassembly.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051916_0009JPG-1.jpg
oestek
04-29-2017, 02:26 PM
Big crate showed up… from DSE!
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051616_0008JPG-1.jpg
One powdercoated Detroit Speed hydroformed subframe. Here, Tara is installing new Baer 6-piston brakes on the spindles.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0034JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0035JPG-1.jpg
Incidentally, Tara came to our shop as a summer intern from an automotive tech program at a local college. She did well in our shop, and became the first recipient of our V8 “Holeshot” Scholarship. She is now finishing up an Automotive Technology degree at Southern Illinois University. Unfortunately for us, she won’t be back as an intern, as she’s got a summer gig lined up at GM in Detroit! Yep, THAT GM! Way to go Tara!
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_051716_0045JPG-1.jpg
Buttoned-up engine sitting proudly in the new subframe, and Baer 6P calipers installed.
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052516_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/04/1969_Camaro_LA_052516_0004JPG-1.jpg
ryeguy2006a
05-01-2017, 10:28 AM
That's an impressive build. It's nice to see a high end build on this site that isn't LS powered. Keep the updates coming!
oestek
05-01-2017, 11:21 AM
Thanks, coming from the guy with LSX in his avatar, LOL! We've got more to come. Thanks again for the kind words!
OLDFLM
05-02-2017, 05:18 AM
Love the updates! What's the story on the red 70-73 Firebird?
oestek
05-02-2017, 08:38 AM
Thanks! The '73 TA is a cool car, it was in for some maintenance.
ryeguy2006a
05-03-2017, 06:27 AM
The funny thing is, I have been seriously thinking of pulling my LS motor out and putting in a Big Block and this build might just give me the motivation to do it!
oestek
05-16-2017, 10:21 AM
Next, the crew reinstalled the painted QUADRALink components, rear shocks, Currie axle, and Baer brake rotors.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_052616_0017JPG-1.jpg
Yellow tape snippets are there to protect pieces during assembly, and also to serve as reminders for things that need to be tightened or filled.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_052616_0022JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_052616_0021JPG-1.jpg
The wheel tubs are yet to be coated with their final treatment.
oestek
05-16-2017, 10:23 AM
Up front, a new Centerforce DYAD clutch is installed and the T-56 Magnum 6-speed is bolted to the bellhousing.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062216_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062216_0002JPG-1.jpg
The DYAD clutch assembly can hang on to 1300 ft. lbs. Of torque, so it should be quite happy behind this big block Chevy. We like these because they also offer a fairly light clutch pedal operation even with the high clamping force.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062216_0005JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062216_0007JPG-1.jpg
wfo guy
05-16-2017, 04:24 PM
Looking good. Was there an obvious reason for the pilot bearing failure?
oestek
05-19-2017, 06:51 AM
The determination was that the clutch got really hot at some point and burned all the crease out of the bearing. The alignment looked OK, but the pocket was full of dust when we took it apart. Seems happy now, however.
oestek
05-19-2017, 07:09 AM
Next, the engine and DSE subframe were installed. The subframe was placed on stands, and the car lowered down over it and aligned.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062716_0007JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062716_0010JPG-1.jpg
Moroso fabricated valve covers were added for a cleaner look.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062716_0013JPG-1.jpg
We patched the previous hole in the transmission tunnel, so a new hole was drilled for the shifter.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062816_0017JPG-1.jpg
The team ran wires for the Holley EFI system.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062916_0020JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_062916_0022JPG-1.jpg
The firewall was chosen as the mounting point for the ECM, as there was limited room under the dash with the Vintage Air A/C system and the customer did not feel the need to have us modify and lengthen the harness if it wasn’t crucial.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_063016_0024JPG-1.jpg
After some re-routing, the wire harness begins to clean up.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_063016_0025JPG-1.jpg
minendrews68
05-19-2017, 09:29 AM
Man, Kevin, you guys do some pretty good work!!
oestek
05-19-2017, 10:25 AM
Thank you sir! We have a very talented crew that really enjoys what they do. I'll pass your kind words along!
oestek
05-30-2017, 07:46 PM
Under the car, the exhaust connections were made. This car came in with a 3” exhaust system, but we needed to modify the system to fit the new subframe and rear suspension. We also wanted to tuck the mufflers up to the floor a bit tighter.
The transmission cross member and driveshaft loop are obstacles in the front of the system, and the DSE QUADRALink makes for a challenge out back.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070116_0003JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070116_0005JPG-1.jpg
We started at the header collectors and the V-Band clamps.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070516_0006JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070516_0008JPG-1.jpg
The mid-pipes were tacked in place, reusing the Black Widow mufflers. The position of the H-pipe was dictated by the transmission cross member.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070616_0009JPG-1.jpg
oestek
05-30-2017, 07:53 PM
Tail pipes were made to snake through the QUADRALink rear suspension and utilized V-Band clamps.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070816_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_070816_0002JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071116_0007JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071116_0009JPG-1.jpg
The whole system was TIG welded together.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071116_0011JPG-1.jpg
These systems are a tight fit, so they take time to build.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071216_0016JPG-1.jpg
oestek
05-30-2017, 07:55 PM
The turn-down is barely visible from the rear of the car.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071216_0018JPG-1.jpg
We wrapped the tail pipes in DEI wrap to help keep heat away from the fuel tank.
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071216_0025JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071216_0030JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/05/1969_Camaro_LA_071216_0031JPG-1.jpg
oestek
06-02-2017, 07:12 PM
Topside, it was time to coat the new steel with some Axalta epoxy and black Imron polyurethane.
The new trunk floor, and DSE wheel tubs and shock crossmember were cleaned and prepped for epoxy and paint. The body was completely masked.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0032JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0034JPG-1.jpg
The tubs were seam-sealed and paint-prepped inside the car.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0037JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0043JPG-1.jpg
New panels blacked-out.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0045JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0046JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0047JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_072016_0050JPG-1.jpg
oestek
06-09-2017, 12:36 PM
Soon the new Forgeline ZX3P wheels arrived. These are 19 x 11.5” rears with 6” BS, Satin Gunmetal finish with fully brushed / cleared lip. The fronts are 18 x 10” with 6.125” BS. We think they look killer on this car, and they really frame the Baer calipers and rotors nicely!
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_080516_0021JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_080516_0023JPG-1.jpg
oestek
06-09-2017, 12:47 PM
The wheels are wrapped in Toyo R888s.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_080516_0026JPG-1.jpg
noob5,000,000
06-09-2017, 07:59 PM
Nice, I love your work!
oestek
06-12-2017, 08:04 AM
Thank you sir!
oestek
06-15-2017, 06:28 AM
The owner wanted upgraded instrumentation in the car, so we approached the dashboard next. First, the top of the dash required some refinishing, so it was stripped, bodyworked, and then went into the paint booth for a re-spray.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_082316_0005JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_082316_0007JPG-1.jpg
New satin black is ready to go!
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090616_0015JPG-1.jpg
oestek
06-15-2017, 06:31 AM
Next, a Detroit Speed steel dash face insert was used to house a full set of Autometer Carbon Fiber Gauges. We’ll install Volts, Fuel, Speed, Air / Fuel, RPM, Oil Pressure, Temp, and Vintage Air A/C controls in this panel.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_081716_0001JPG-1.jpg
Design sketched out
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_081716_0002JPG-1.jpg
Measure 3 times!
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_082316_0008JPG-1.jpg
Holes cut, A/C control going in for test fit
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_082316_0009JPG-1.jpg
All holes cut, bodywork done and sprayed in satin charcoal to compliment the trim colors on the car.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090616_0011JPG-1.jpg
Note 3 LED light holes above center gauge for turn signals and high beams.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090616_0013JPG-1.jpg
All gauges installed and wired, with a weatherpack connector for easier installation.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090716_0018JPG-1.jpg
oestek
06-15-2017, 06:33 AM
Tyler says “Ta Daa!”
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090716_0019JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090716_0020JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_090716_0021JPG-1.jpg
All new Dynamat sound deadener installed throughout the cabin.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_092016_0001JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_092016_0003JPG-1.jpg
New dash panel installed with headlight and Detroit Speed / washer switches mounted below.
https://static1.pt-content.com/images/pt/2017/06/1969_Camaro_LA_092016_0005JPG-1.jpg
oestek
07-10-2017, 05:24 PM
The dash pad changed colors to black, and the rest of the interior was reinstalled.
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_093016_0002JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_093016_0003JPG-1.jpg
Trunk carpet reinstalled
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_093016_0004JPG-1.jpg
There was a thought to go with a carbon fiber Anvil rear wing, but the owner decided against it and went back to silver.
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_100516_0011_JPG-1.jpg
It looked cool, but it’s all a matter of personal preference.
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_100516_0036JPG-1.jpg
Finally the wheel tubs were detailed with epoxy, and Imron.
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_101716_0005JPG-1.jpg
oestek
07-10-2017, 05:26 PM
We set the ride height and had the car aligned, put a new base calibration in the Holley ECM, and took it out for a spin! Looks sweet!
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_101816_0035JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_101816_0047JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_101816_0060JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_101816_0070JPG-1.jpg
oestek
07-10-2017, 05:31 PM
Tow loop added
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_122016_0024JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_122016_0021JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_122016_0025JPG-1.jpg
https://static1.pt-content.com/images/pt/2017/07/1969_Camaro_LA_122016_0023_JPG-1.jpg
oestek
09-26-2017, 07:16 PM
The V8TV video covering this build...
https://www.youtube.com/watch?v=LlJ3yb0MqR8
oestek
02-01-2018, 04:28 PM
This phase of the project is complete, but wait, there's more! We've started a new chapter on this Camaro upgrading the Big Block Chevy V8 to a supercharged Chevrolet LT4 V8!
Click the link to read the new thread and follow along!
NEXT CHAPTER:
https://www.pro-touring.com/threads/127603-1969-Camaro-Transforms-From-Big-Block-to-Supercharged-LT4-V8-at-V8-Speed-amp-Resto-Shop?p=1255942#post1255942
