View Full Version : 1.69" Taper to 1.5" Taper
DA4AD
03-21-2017, 05:17 PM
Would anyone happen to know if I can change a 1.69" Taper to a 1.5" taper in a spindle?
I would like to change the upper BJ from a K778 ball joint (1.69" Taper) to a K772 ball joint (1.5" Taper) if possible.
If done some research and Howe racing sells a longer stud if needed.
astroracer
03-22-2017, 03:21 AM
Keyser Manufacturing has some taper adapters available.
http://www.keysermanufacturing.com/Ball-Joint-Holders-and-Rings
Part Number: 100 398-1
You will have to talk to them about the outer taper, their description doesn't state what is. Maybe they could make some for you...
Mark
cdrod
03-22-2017, 04:39 AM
Could you use a reamer to change the taper in the spindle? I'm not sure how much material you'd have to remove but in principle, it seems like it could work. I bought a 7-degree ball-joint reamer tool from Speedway to clean-up my factory spindles. Here the link:
http://www.speedwaymotors.com/Speedway-Tapered-Ball-Joint-Reamer-7-Degree,2918.html
Let us know if this works out.
Rodney
astroracer
03-22-2017, 05:04 AM
Rodney
Without knowing the actual taper diameters I have to say reaming it will not work. If the ball studs are similar in diameter and a 1.69 taper is already in place the 1.5 taper is too small to "ream" too. Material would have to be added to the 1.69 taper to be able to ream it out for the 1.5. A shim is a good alternative if you can find or have one made.
DA4AD
03-22-2017, 03:57 PM
Thanks for the responses, I sent Howe racing an email and will await their response.
