View Full Version : Fuel Sending Unit for Early SBC
minendrews68
03-09-2017, 07:13 AM
Does anyone make a "in tank" fuel pump for a carbureted engine? I have mounted my Holley electric fuel pump everywhere, even with rubber between the pump and sheet metal and it's still really loud inside the car.
Schwartz Performance
03-09-2017, 10:35 AM
Not sure about low pressure,but we have done standard efi in tank pumps but need to run a bypass regulator to make it work.
I'm sure you could use an early TBI pump from a 3rd gen and make it work..?
dontlifttoshift
03-10-2017, 09:42 AM
We have done as Dale says several times. TBI pump in a Tanks tank with an aeromotive bypass regulator with return line back to the tank. Quiet and reliable.
HandOverFist
03-10-2017, 11:22 AM
http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=84/category_id=61/mode=prod/prd84.htm
minendrews68
03-12-2017, 03:09 PM
Thanks guys, One person I talked to said the LS type are too long and require them to be shimmed up at the top. They bottom out on the bottom of the thank. I have a Holley bypass regulator.
