jwcarguy
03-05-2017, 01:10 PM
I have some LS3, LS7 parts available, these will work in other engine (please verify your fitment) ie LS1 , LS2 , LS6 5.3L , 6.0L 6.2L Vortec
cams:
- GM stock LS7 3 bolt #12638426 (#8426) Specs: 211/230 .588/.588 120.5 lsa (w/ 1.8 rocker) (.558/.558 lift w/ 1.7 rocker)
This is a new take out w/ 4 miles on it SOLD!!
- Comp Cams LS3/7 3 bolt cam LSL lobes #13017R/13021R specs: 227/243, .614/.624 (w/1.7) .650/.661 w/ 1.8 rocker)
low mileage 3k miles $280
- Comp Cams / Ragin' Racin' "Stalker" cam specs 224/246 .661/.661 115 w/ 1.8 rocker (.624/.624 lift w/ 1.7 rocker)
Description from Ragin Racin website:
Stalker cam
224/246 115 LSA .661/.661 lift (1.8 ratio)
Great daily driver, Minor lower rpm surge, Aggressive cam lope, Great HP and torque increase through out the RPM curve. This cam is track proven to put many larger LS7 cams to shame at track with trap speeds of 136+.
http://www.raginracin.com/main/cams/
$225
- LS7 rocker arm complete set , includes offset intake and exhaust rocker, stock take offs SOLD!!
- LS7 / LS3 Z06 / Grand Sport Corvette Dry Sump Oil Reserve Tank, in excellent condition, includes mount brackets and sensor
SOLD!
- LS3 / LS7 Fuel Injector set #12576341 (42#/hr), low mileage take outs, went to larger injectors SOLD!!
- LS2 / LS3 / LS7 / Vortec Ignition coil set, includes mounting brackets, coil harnesses (coil #12611424) SOLD!!
in Las Vegas
Call/Text (702)677-4085
cams:
Stalker cam
$225
SOLD!
in Las Vegas
