View Full Version : Need help with 18" wheels on 67 Chevelle.
Alwhite00
03-03-2017, 01:31 PM
Borrowed a 285/40/18 from a buddy and it is on an 11" wheel so its right at 300mm. It fits but only 1/4" on the inside and maybe 1/2" at the wheel lip. I'm looking at getting 285/40/18's on a 10" wheel on the rear with 6.25bs. I added an extra 1/4" in case I add disc brakes.. Anyone have any experience on a 66/67? Car is lowered BTW.
I'm lookin at a 18x8 in the front with a 245. I had 245/45/17 on the front with 0 offset and it rubs the wheel house. I'm thinking the 8" with 5.75bs but that seems like a lot. I did bolt on a 18x8 with 5"bs and although it cleared it was still extremely close with the wheel straight.
I have dropped spindles, tall ball joints and factory style disc brakes.
Looking for some input.
Also looking WOR 18" wheel choices with custom offset around the $400 range. I have found TTII and salt flats but would like more options.
HandOverFist
03-03-2017, 10:46 PM
No help with a car, but I bought some 18" Vision 143's for the El Camino...would look great on your car.
https://static1.pt-content.com/images/pt/2016/11/Vision20wheel20image_zpseocmcyxd-1.png
18x8.5 w/5.1BS for the front and 18x9.5 w/5.75BS on the rear.
https://static1.pt-content.com/images/pt/2016/04/sheet20metal20009_zpsjwffx1ae-1.jpg
https://static1.pt-content.com/images/pt/2016/09/change20of20plans20002_zpsnhefnqwg-1.jpg
all4sho
03-04-2017, 06:10 AM
i am intrested in the same info, if you can find any that is
Alwhite00
03-04-2017, 01:02 PM
HOF, the wheels look really nice on the elco, are custom backspace available?
HandOverFist
03-04-2017, 01:06 PM
Not custom, but they are available in a wide range. Check them out on the Summit site to see if they offer what you seek.
Alwhite00
03-04-2017, 04:18 PM
Yea, they don't. :(
HandOverFist
03-04-2017, 04:28 PM
You could narrow the housing to get where you want to be...another option to weigh. I narrowed mine slightly and it helped fitment...also added Ford housing ends and it opened up disc brake options as well.
https://static1.pt-content.com/images/pt/2016/12/1220bolt20004_zpsxrl8w9u0-1.jpg
Alwhite00
03-04-2017, 07:21 PM
The rear is not the problem, the front is.
HandOverFist
03-04-2017, 08:34 PM
Spacers?
Alwhite00
03-05-2017, 01:19 PM
Spacers?
I need to go in, not out. Did you read the issues I spoke about?
HandOverFist
03-05-2017, 02:52 PM
Yes...from your first post - "I'm lookin at a 18x8 in the front with a 245. I had 245/45/17 on the front with 0 offset and it rubs the wheel house. I'm thinking the 8" with 5.75bs but that seems like a lot. I did bolt on a 18x8 with 5"bs and although it cleared it was still extremely close with the wheel straight."
My thoughts were simply to try a larger BS wheel and use the spacer to bring it back out where you need it...carry on.
ignaro
06-22-2017, 07:51 PM
What did you end up going with? I've got similar fitment issues on my 66 Tempest.
