View Full Version : 2000 Z28 A4 Engine Harness, $250 shipped.
SSleeper
02-20-2017, 09:25 PM
Perfect condition, very clean. No cuts, splices, repairs, or damage. Took this off a 42k mile Z28 A4.
SOLD
I may also have pigtails to use on a T56 (speed sensor and rev lockout connectors) for someone to splice on and re-pin the ECM connectors to work with a M6 ECM, but I'll have to check.
Tpichevy
02-20-2017, 09:47 PM
Newbie question....I found a 2005 5.3 truck engine low miles for sale with no harness. How would this work with a setup like this?
SSleeper
02-21-2017, 06:16 AM
I don't follow 5.3s much so I don't know the differences from year to year on those, someone with more knowledge will have to chime in or put up a post on a main forum. But, if that engine has a 24x reluctor wheel, a cam sensor at the rear of the engine, and you use ev1 style injectors, then it will work fine if you use a 99-02 f-body pcm (or possibly 99-04 vette pcm). I assume you'll be removing most of the emissions plugs so those won't matter.
To tell the difference, the crank sensor body color will be black on a 24x engine, and gray on a 58x engine...the crank sensor is on pass side of the block towards the rear behind the starter. If it's a 58x, then this will probably not work. From pictures I've seen, a 2005 5.3L (VIN T) has a rear mounted cam sensor like the LS1s.
Hope this helps.
