68Malibu383
02-14-2017, 05:46 PM
I'm back with more info. I posted this problem some time ago, made some changes, and ran in one more autocross and the same problem occurred.
To recap... I have a '68 Chevelle with a late 80's Monte Carlo SS steering box. Been running that combo for about 20 years using the Lee Mfg fitting adapter in steering box and a stock reman '68 PS pump.
During normal driving, everything works fine. When autocrossing, the pump whines and steering becomes jerky. After running fluid spewed out from the PS pump cap.
The assumption was that the fluid was overheating, but it is not. Since my first post, I installed a large transmission cooler (fin not plate) and last time I ran the car, it was 40 degrees outside and the whine began after the first turn (made a hard left, turned wheel back and whine began.) Fluid and reservoir were very cool to the touch after the run but looked aerated. I also installed a different pump cap (restoration "correct" type cap) and changed the fluid (Prestone) and blead the crap out of the system (and drove the car 200 miles to the event the night before, so I don't think any air was left.)
Someone asked the sizes of orifices when I posted originally, so I'll list them below.
Long story short, I'm converting to the AllStar Type II pump system (pn 48242). I'm hoping that will cure the problem but I hate throwing parts at something without knowing the real problem.
If anyone has any ideas, please let me know.
Opening in Pressure Outlet fitting on the pump going to steering box ~.145-.150
Inlet in steering box from pump is ~.340 (this is the opening size of the Lee Mfg adapter so I don't know what is below this)
Return opening in steering box is ~.315
I'm also running an A1 Cardone Magna-Pure Inline Power Steering Filter (pn 20-0012F). I never did take that out of the equation...
