View Full Version : Brake booster boot and firewall hole
Brianstanford
02-13-2017, 05:25 PM
Car is a 67 camaro drum/drum. Converting to power disc/disc. Booster is a Tuffstuff 9" dual diaphragm. Using DSE brackets.
The question I have is when installing the booster the boot on the back is bigger than the original hole in the firewall but about 1/8". If I try to install it the booster/brackets leave about a 1/4" gap. Is the boot supposed to fit inside the hole? Thanks
pics of boot and hole and firewall
137098137099
Brianstanford
02-14-2017, 03:23 AM
Think I found my answer137106
PonchoJohn
02-16-2017, 11:47 AM
Do you have this pic as a file that can be printed?
b17brian
02-18-2017, 08:52 PM
I just installed the same booster and brackets on my 67 Camaro. At first I thought I had to trim the hole. I realized that if cut the hole bigger I won't have a seal keeping water out of the interior if I wash the engine bay.
So I removed the rubber boot and installed the booster to check for interferance on the booster / firewall and I had none. I removed booster, pushed the end of the rubber boot through the firewall, and reinstalled booster seating the other end of the rubber boot on the booster as I installed it.
Now I have a water tight seal on my firewall.
72poncho
02-19-2017, 07:34 PM
i second ponchojohn, im installing a similar booster/master combo in my lemans
psiconversion
03-15-2017, 05:04 PM
He careful. I used that bracket on my 65 Buick and it caused the brake rod to break. It seems that the low angle bracket needs a new hole drilled in the pedal, somewhere between the manual and power holes.
Fritz
11-22-2017, 09:27 AM
I just had the same problem with my 69 firebird, using the same parts. There was about 1/4" of space between the brakes and the firewall but I pulled it in by tightening the nuts up on the studs. Now I'm wondering if I need to take it apart and enlarge the hole.
LSx442
11-27-2017, 04:13 PM
would a shorter rod prevent it from binding?
Steve68
12-01-2017, 06:24 AM
How does your booster fit with the DSE brackets? have any pics?
Fritz
01-23-2018, 11:01 AM
Well I took it back apart and enlarged the hole slightly with a die grinder. I re drilled the brake pedal because it did indeed not line up correctly. Then the problem became that the pushrod is not long enough. So I'm the process of trying to take the double nuts off the old pushrod and I f'd up the threads so now the booster needs to come off a third time. pita
148188148189
