View Full Version : any other 67-69 f bodies running ls3 accessories
TXsilverado
02-13-2017, 01:56 PM
I would like to see what you did to make it fit, and if you have hose numbers for the radiator/pump.
I bought somone elses project and i'm slowly working my way through it. I finally gave up on the S&P conversion mounts fitting my combination and went with dingo sliders so I can slide the motor back to get everything happy. now I realize I need to cut/box the frame. the prior owner has some kind of aftermarket thermostat housing and aftermarket flexible radiator hoses that leak....i'd like to see your methods of boxing frames and what hoses you used for a clean install.
oleyeller
02-13-2017, 03:28 PM
Why not try using the Dirty Dingo Accessory mounts? They work well with the sliders on a first Gen. No need to chop up the subframe.
dhutton
02-13-2017, 03:33 PM
Are you talking about factory LS3 accessories? Camaro or Corvette? Maybe post some pics.
Don
TXsilverado
02-14-2017, 08:28 AM
yes, sorry. the factory LS3 accessories for a 2010-2015 N/A Camaro with a 8 rib system. I'm stuck using these accessories because I'm running a kenne bell blower that's built to use these accessories. once upon a time It had the dirty dingo low mount alternator bracket and it flexed too much and threw belts. it would be fine without the blower but the kenne bell put too much stress on it. the OEM bracket is stronger when not using a 3rd gen alternator with the rear bracket that bolted to the block. the Camaro accessories (the low mount alternator) fit using S&P mounts with some massaging with a BFH. with the sliders slid back to fit my new headers, the alternator needs more room. a BFH wont take care of it this time. I'm running a high mount AC compressor, so no worries on the passenger side K member.
this is the only pic I have under hood. Can't see much with all the blower/intake/pluming.
https://static1.pt-content.com/images/pt/2016/04/4C5CA97B86D64BE88F6696F65EC02AC9_zpsqlru-1.jpg (http://smg.photobucket.com/user/StewartSmith/media/4C5CA97B-86D6-4BE8-8F66-96F65EC02AC9_zpsqlruck0o.jpg.html)
130fe
02-14-2017, 09:35 AM
137124I am running the Corvette accessories with the Holley AC setup. No issues at all. The Holley stuff is nice also.
