View Full Version : Inspection failed me for rear brake lines - Need to fab a bracket. Suggestions?
Poxic
02-07-2017, 06:59 PM
http://goo.gl/photos/wWjzpnmXfSBaEPcB7
I hope this picture shows up for you guys.
I took my 74 Nova in for an inspection and the tech failed me for having improperly mounted rear brake lines. It's been this way for 7+ years and this is the first time it's been flagged.
The rubber lines are supposed to be fixed to the axle in some way. Any suggestions on a good way to set that up? Rear kit is a Right Stuff disc conversion on a stock 10-bolt that used to be a drum setup.
another69
02-07-2017, 07:39 PM
Mig weld a bracket that holds the brake hose to the axle housing and use shorter brake lines on the axle. The brackets are pretty common from circle track suppliers, etc.
Schwartz Performance
02-07-2017, 07:47 PM
https://static1.pt-content.com/images/pt/2017/02/dscf2885-1.jpg
TheJDMan
02-07-2017, 07:49 PM
I can see why they failed it. There are all sorts of suppliers for weld on brake line mount tabs. Here's one from Speedway Motors.
http://www.speedwaymotors.com/Brake-Line-Mount-Tabs-with-Clips-Pack-of-4,1973.html?sku=91031310&utm_source=bing&utm_medium=cpc&utm_campaign=SMI%20-%20Shopping%20(CSE)%20(Bing)&utm_term=1100309979714&utm_content=All%20Products%20(M31)
icemanrd19
02-08-2017, 05:21 AM
if you want a set of real nice ones
http://www.jcgrestorationandcustoms.com/product/rear-end-brake-line-clamps/
HandOverFist
02-08-2017, 06:29 AM
Why not just use these? http://www.moserengineering.com/other-parts/brackets-perches-and-braces/part-6blclamp.html
Shawn01754
02-08-2017, 05:39 PM
how about zap it with a stick welder and loose the clamp.. nice to see your ready to roll!
