cwylie
02-06-2017, 08:37 AM
Not 100% set on selling this car but I have the bug for something else. This is a great car. Turn it down and drive it to dinner or turn it all the way up and have some fun. Very sorted setup with the cooling to handle the HP and no issues being a street car. Stereo work, A/C works, mild driver until you put your foot in it.
2007 C6 Fully Built Twin Turbo with 22k miles, 1100whp on e85 and 800whp at 10lbs on 93, Tuned by James Karger. The drivetrain is fresh with less than 5k miles.
ENGINE
ERL LS7 block with recent refresh. Cylinders were cleaned up and has new wiseco 4.135 pistons and compression was set to 10.5:1, Callies ultra H-Beam Rods, dragonslayer crank, All bearings were replaced as well as a new kateck oil pump. WCCH ported ls7 heads and stock ls7 intake manifold, Pfadt engine mounts. Turbo kit was built by ips motorsports, Low mount twin Forced Performance gt3586r HTA billet wheels. Turbos were also serviced and inspected by forced performance ago during the refresh. Flex fuel sensor. Katech Valve covers and coil brackets. ATI damper. Katech Belt tensioner. Mezier WP419 Billet mechanical water pump, Dewitts radiator, D3 dual spal fans. Full dual 3 inch exhaust with center exit for Breathless performance diffuser. Mechman 220amp billet alternator.
DRIVETRAIN
New Mantic triple clutch, Driveshaft Shop 3.5 inch aluminum driveshaft, RPM z06 level 6 Tr6060 and stage 3 z06 diff, Pfadt trans mounts, MGW shifter with billet shifter box, line lock, half shaft safety loops. New Z06 front brakes and base brakes to fit 15 inch rear wheels.
SUSPENSION
Pfadt coilovers, Delrin suspension bushings, LG drag spindles, Forgeline 19” GA1R with Toyo r888 all the way around, Weld RTS 15” with 315 ET Streets
INTERIOR
Caravaggio race seats, Caravaggio center console lid, Caravaggio E-brake lever and boot, Defi boost and fuel pressure gauge, Ethanol gauge, Boost leash Boost controller with on board Viair air system, NGK AFX wideband, Fire extinguisher, Touch screen double din stereo, focal 3 ways and JL amp.
Exterior
MCM carbon fiber hood, C7 ZR1 front carbon splitter, Extended carbon rear spoiler, Carbon Zr1 Side skirts and Breathless performance rear diffuser.
Asking $55k, or possibly interested in a trade for another fun street car. Up or Down. Something along the lines of a ZR1, 911 or Pro Touring muscle car.
https://static1.pt-content.com/images/pt/2017/02/8013528905_10153758819572705_61078372132-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20160624_184411-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20160624_184434-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20160611_203951-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20161028_175816-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20161028_175759-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20170206_093932-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20170206_093957-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20170206_093951-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20170206_093925-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8013090650_532182420316975_2092870434_o_-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8013090809_532182426983641_567696613_o_f-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8020150224_212518_zpsabbqcxik_bed941ed74-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8020150224_212550_zpsepmjajvv_383d21b5d1-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8020150225_192509_zps3tz9uhlj_1__8cf5452-1.jpg
https://static1.pt-content.com/images/pt/2017/02/8020150302_202437_zpslohkq9nx_cc63512558-1.jpg
https://static1.pt-content.com/images/pt/2017/02/IMG_20170206_093904-1.jpg
ENGINE
DRIVETRAIN
SUSPENSION
INTERIOR
Exterior
