View Full Version : Shocks fully extended do not reach spring perch at full droop
AU Doc
02-04-2017, 05:07 PM
I'm replacing the rear mono-leafs in my 1969 camaro with some Global West springs, I'm upgrading to Del-A-Lum bushings, and adding double adjustable Varishocks while I'm at it. I had to use a DSE multi-leaf adapter since i'm going to multi-leafs.
The last step was to attach the shock on the first side I finished up and realized the shock won't extend all the way to the shock mount. It's maybe two inches too short? Is it normal for the shock to limit how much the rear end will drop?
Thanks for the help - and now to figure out how to get the grease off my keyboard :hmm:
HandOverFist
02-04-2017, 06:19 PM
Fairly common...more important is your available travel with the suspension loaded.
AU Doc
02-04-2017, 06:28 PM
Awesome! Thanks for the feedback. Since it's highly unlikely I'll be jumping anything in the car to completely unload the rear suspension, I assume the shocks should be able to tolerate holding the diff and springs up when I jack up the car? that is, I shouldn't have to disconnect the shocks before I jack up the rear?
HandOverFist
02-04-2017, 06:31 PM
That's how it is with most cars. If the shocks were taken loose on my El Camino the coil springs would fall out when on the lift.
AU Doc
02-04-2017, 06:55 PM
Hahaha! I hope that's a lesson you read about rather than learning from experience!
Thanks again for the help!
HandOverFist
02-04-2017, 07:00 PM
Lol...it just happens that is the only way to remove the rear coil springs in most cases. Btw, if using some lowering coil springs in the rear they will fall out if you don't adjust your shock lengths...yes, I have done that hehe.
AU Doc
02-05-2017, 07:48 AM
I wish there was a like button. I would have clicked it :)
