View Full Version : bb 427 tko 600 rear gear raito
Gmc427
02-01-2017, 01:55 AM
hi,after advise on rear gears, running 427 bbc xe274h cam ,450ish hp,wanting to run tko600 with tall od for low rpm driving,26.5" tall rears was thinking 3.5 but now think that maybe to tall for good of the line?3.7-3.9?thanks and regards
71RS/SS396
02-01-2017, 04:27 AM
In one of my previous cars I used 3.73 with a 26.7" tire. I was able to knock down 20 mpg on the highway with a carbed BB.
Craig@Bowler
02-01-2017, 10:11 AM
Just to give you an idea of where you will be so you can better plan the build. Using a 26.5" tire and the TKO600 with a .64 OD here is where you will be RPM at MPH for each gear set in 5th gear.
3.50: 1800rpm-63MPH , 2000rpm- 70MPH, 2200rpm- 77.5MPH, 2400rpm - 84.5mph
3.73: 1800rpm-59.5MPH , 2000rpm- 66MPH, 2200rpm- 72.5MPH, 2400rpm - 79mph
3.90: 1800rpm-56.8MPH , 2000rpm- 63MPH, 2200rpm- 69.5MPH, 2400rpm - 76mph
I can send you a complete spread sheet on each ratio in all gears up to 5600RPM with driveshaft RPM as well or compared to the .82 OD. Main thing is to plan the gearing around what your target cruising RPM is and what your engine will like as well with that cam if your focus will be on MPG.
Gmc427
02-02-2017, 12:55 AM
sounds good,email you at bowlertransmissions?regards
Gmc427
02-02-2017, 01:08 AM
hi was that running a five speed?regards
Craig@Bowler
02-02-2017, 07:35 AM
Yes. and my email is [email protected] feel free to send me a message and I'll get you some info. Thanks.
