jwcarguy
01-30-2017, 09:02 PM
I am looking for a new or near new std bore LS7 (427 cid) engine block to either assmbly a engine,
I have a complete LS7 engine that had only 4 miles, yes 4 miles on it and GM tech found issue with #3 piston assembly, during initial startup
So I need a new engine block, already priced my cost at Chevy dealer, just checking to see if one was out there first
I have complete new (4 mile) LS7 rotating assembly with bearings/ rings (have new piston assembly too) forged crank, titanium connecting rods, & coated pistons
All NIB GM coated main & Rod bearings sets
CNC Ported LS7 cyl heads complete, w/ rockers/ stands, bolts
LS7 Cam, timing set, lifters & trays
All NIB GM gaskets , seals & bolts (for entire engine)
all covers (front, rear, valve covers, LS7 valley, w/ seals)
LS7 Intake manifold ,w/ NIB LS7 DBW Throttle body, GM fuel rails
LS7 Dry Sump oil pan assembly , oil pump and dry sump oil reservoir tank (Corvette)
LS7 Balancer
Ignition coil packs & brackets
pic for attention
In Las Vegas, NV 89131
Please pm/ call/ text if you have a block
(702)677-4085
LS7 Balancer
pic for attention
(702)677-4085
