View Full Version : Electrical Issues
CMT
01-28-2017, 09:05 PM
Hello. I'm working on a 1970 pro-touring trans am project. It's been a thorough rotisserie restoration. My problem is that the fuel and voltage gauges bounce all over the place. At a stop light they will pulse with the turn signal. I have brand new auto meter gauges, brand new wiring harness, LS-6 engine, new alternator. From what I can tell the car is grounded properly. Any ideas on how to fix this?
130fe
01-29-2017, 03:43 AM
Sounds like all of the gauges and turn signal lights share the same ground for the dash. I had this with a a set of autometers I used to have in my car. Have the turn signal light ground all by itself and put the gauges in another ground location and your issue will go away.
astroracer
01-29-2017, 06:45 AM
How is the alternator wired? 1 or 3 wire? If it's a 1 wire set up that will also cause gage fluctuation as the alternator is trying keep up with system voltage demands.
Mark
CMT
01-29-2017, 07:33 AM
Thanks Chris and Mark. I'll check all of that out and get back to you with an update.
blitzer454
01-29-2017, 08:43 AM
Also make sure that your dash ground is not electrically isolated from the body ground. You might be missing some ground straps somewhere.
minendrews68
01-29-2017, 01:24 PM
From what I've encountered.. you can't have enough grounds. Just make sure they're the proper gauge wire. I have grounds from the body to the frame etc.
