View Full Version : 1969 Buick Electra Project Car
pacwes
01-25-2017, 11:23 AM
13645113645813645513645213645913645613645313645013 6457136454
https://youtu.be/5Vx3NM9mOCg
This car is perfect for SEMA build
Asking $16,000.00
5.3 LS motor and tranny pulled from Tahoe custom suspension to make the car layout flat on the ground, laying a frame on a car this big with things that get in the way like a convertible roof is quite an accomplishment the entire floor has been removed and redone with new sheet metal countless hours have been put into this car. To make it sit as low as possible with a 22 inch rim and big disc brakes all the way around the rear floor section has Provisions for a plexiglass window to be installed after the upholstery is done, so that you can see the custom suspension with the convertible top up or down. From front and rear the suspension is completely one off hand-built suspension and parts. A lot of money and time has been invested in this car it needs a good home and to be completed some sheet metal and some Fab work needs to be done but the car is about 80% done mechanically. Cosmetics obviously is about 10% with the majority of the rough body work being taken care of. A primer sealer has been laid down on top of all the custom work to protect it.
Title is in hand.
