View Full Version : Engine Removal Question
JoshStratton
11-17-2005, 12:57 PM
Which bolts do you all attach your cherry picker to when you are removing your engines? I am about ready to pull and the bolts I am looking at are kind of tiny and on the head.
smittys69
11-17-2005, 01:12 PM
You can use an adapter plate to mount in place of your carb on your intake manifold and pick there or use your intake manifold bolts (front and rear - opposite of each other) to pick from. Make sure that your bolts are strong enough though. You might go pick up some grade 5 or grade 8 bolts for those locations just for the pick.
baz67
11-17-2005, 01:17 PM
what he said
camaro608
11-17-2005, 01:55 PM
buy one of these...it will help
Rocko71
11-22-2005, 08:11 AM
i just thread long bolts through the chain link and on opposite sides of the intake manifold bolt holes. I use big washers to keep the chain from sliding over the heads. its cheaper than buying one of those plates and works just as well.
JoshStratton
11-22-2005, 08:34 AM
I ended up buying one from Jegs since they are right down the street. It actually worked really well. I wouldnt trust it to hold the thing long term, but it did it's job.
Thanks!
12-10-2005, 10:08 PM
I use a Harbor Freight leveler with four chains. Turn the crank and you can raise or lower the back of the engine, even if it has the trans on it.
JoshStratton
12-11-2005, 06:32 AM
Thanks! I am going to get one of those when I put an engine back in. I was going to go to Jegs but now I will check out the Harbor Freight one.
Maxoctane
12-13-2005, 11:28 PM
i use a leveler also that i got from kragen and just use 2 grade 5 bolts in the heads. when you reinstall the engine wrap the ends of the chains in shop rags or you'll damage that freshly painted engine!
