View Full Version : Driveshaft & pinion & rear angle
timopajala
01-21-2017, 03:03 AM
Are these angles ok? My transmission is 3-4° down, rear is about 3° pointing up and driveshaft is about 0°
Car is 1967 camaro with tr6060 and ls3
sccacuda
01-21-2017, 03:22 PM
If this is a leaf spring car, I'd say no. The rear end will rotate up on acceleration and driving, probably 1-1/2 to 2 degree's. So you need to compensate for that on the static setup.
oleyeller
01-21-2017, 03:39 PM
If you have a cell phone, download the Tremec Toolbox App. Nice tool box with some handy things. Driveline angle tool works great. Use your phone to determine if your angle are correct.
timopajala
01-21-2017, 08:16 PM
i tried to install that app but did not get it to work on my phone for some reason. I have leaf spring car so i make the adjustment to compensate the 1,5-2 degrees that comes from acceleration. Thanks for the answer!
