View Full Version : Ls swap power steering problems
408maro
01-16-2017, 07:48 AM
I am towards the end of my ls3 swap in 72 camaro and seems like everything becomes some sort of obstacle..
I have purchased the holley alternator relocation kit and purchased the recommended c5/c6 power steering pump which I got from turn one..
The problem I am having is that the pulley is litterly right on the fitting for my power steering pump..
Looks to be about 6.5" overall for pulley.. any suggestions?
If I somehow find a smaller pulley do I got to get a smaller balancer? Is there a different type of pump fitting I can use?
https://static1.pt-content.com/images/pt/2017/01/20170115_124849_zpsp7zmgdkp-1.jpg (http://s296.photobucket.com/user/408maro1/media/20170115_124849_zpsp7zmgdkp.jpg.html)
https://static1.pt-content.com/images/pt/2017/01/20170115_125855_zpsdjfyjaai-1.jpg (http://s296.photobucket.com/user/408maro1/media/20170115_125855_zpsdjfyjaai.jpg.html)
Samckitt
01-16-2017, 08:49 AM
When I swapped the LS into an 86 Monte, I had same issue, I used smaller pulley, I believe it is for a CTS-V, GM part number 12578552.
408maro
01-16-2017, 09:31 AM
Thank you. DId you have to use a underdrive pulley also?
Samckitt
01-16-2017, 09:35 AM
i didn't change balancer. Figure there isnt a big difference, & figured the crank pulley is the same dia for all, & doubt pumps are that much different.
Also FYI, the part number above is discontinued, but buddy at GM dealership says there is 3 dealers that have them in stock still.
dhutton
01-16-2017, 10:35 AM
I think Holley sells a smaller diameter pulley.
Don
nats68
01-24-2017, 09:56 AM
Dirty Dingo sells a smaller pulley also. Put one on my 68 Camaro with an LS3. Pulley was real close to the upper control arm.
