72Z/28
01-13-2017, 10:05 AM
Just wondering who has the following set up in his 1st gen camaro:
-Speedtech performance front clip
-Autokraft oil pan and their engine adapter plates and mounts
-Stainless steel works header (speedtech headers).
I know Evade Camaro has got this exact set up.
The reason why I am asking is that the unisteer rack and pinion mounting bracket was modified due to clearance issues caused by Milodon oil pan.
I recently replaced the Milodon oil pan with Autokraft Oil pan and also got their engine adapter plates and mounts.
I tried to install the rack and pinion at its proper mounting position on the Speedtech subframe. Unfortunately, I ran into two issues:
1) steering box high and low pressure ports were touching the oil pan ( very tight fit)
2) the shaft that fits between the u joint was a bit short due to the previous modification made as a result of clearance issues by Milodon oil pan.
Will appreciate your input guys on the following:
- is it normal to have a very tight fit ( steering box ports and oil pan)
-I had to order a new steering column shaft ( it is 23" that needs to be shortened). So could somebody tell me the required shaft length with the set up listed above?
I addressed the issue with the tight fit to Speedtech team, unfortunately no response yet.
Looking forward to getting your input guys.
