View Full Version : Primer question for you paint guys
JoshStratton
11-17-2005, 07:31 AM
Last night I was looking at my fenders, which I primed at different times a few months ago. One of them is really glossy and thick looking...almost like orange peel, but not really orange peel. The other is light, kind of ruff and dull in shine. Are either of these close to the kind of texture you want with your primer? I used PPG DP90.
The reason I am asking is because it has been a while and I cannot remember what I did to get each coat. I am not too experienced with laying paint and want to figure out what the standard is for priming. If I have a good example then I will have something to shoot for, no pun intended.
Sorry, I do not have pics right now.
Travis B
11-17-2005, 08:06 AM
Well since it is primer...technically it does not matter but it should have a dull shine and be pretty smooth
astroracer
11-17-2005, 08:44 AM
The "look" after spraying is really unimportant with most primer applications. Most primers will be blocked sanded or scuffed in some way before topcoat so, what you are "shooting" for, is good adhesion to the base and a consistant film thickness.
Mark
73z-6sp
11-17-2005, 09:04 AM
I agree, the finish of the primer really isnt that important. But..the more textured it is the more block sanding you may have to do so strive to always spray anything as best you can and you will be better off because of it. I mean, where else are you going to get the experience of spraying paint with out the fear of screwing up the final product. So I say shoot it as if you were spraying the topcoat.
Good luck!
JoshStratton
11-17-2005, 09:16 AM
Thanks for the info guys! I thought I was being a little paranoid. I actually agree with your ideas on priming as if you are shooting the final.
In fact, that is why I went out and got an air compressor that will handle a really nice gun. I was using a 30 gallon compressor before and had to use a LVHP gun. I wasnt too crazy with the way they shoot. It was a great compressor for a lot of the other tools I needed it for, but I think I will be WAAYYYYYY more happier with painting with the new 80 gallon one I got. Any tips on good guns for pimers and BCCs?
73Z-6sp: Mind if I ask how you managed to get the insides of this cleaned before painting? http://home.earthlink.net/~roopdogg/18.jpg
Travis B
11-17-2005, 10:07 AM
Sata makes nice stuff, along with Binks and Devilbiss(spelling).......
J2speedandcustom
11-17-2005, 10:51 AM
Kuhlryde - what pressure are you shooting the primer? This will also affect the finish, and said before practice is key. Try shooting at 30 - 35psi at the gun, your compressor will probably have to be turned up to around 100 to get that kind of steady pressure at the gun.
On your primer descriptions it sounds like the first one was more wet "more paint" to get the heavy orange peel. The 2nd sounds more dry coated "not enough paint" like you didn't overlap enough or went to fast with the gun.
Good luck and have fun! :)
73z-6sp
11-17-2005, 11:30 AM
Well, I was fortunate enough to have a new hood to work with on that one. I have done original hoods and it can be a PITA. I usually clean the heck out of it with some degreaser/bon-ami, then wet sand it, metal prep and condition, then spray on the primer/surfacer. It is much like painting anything else except you REALLY got to watch your fingers if you want to keep them intact!
JoshStratton
11-17-2005, 12:02 PM
Actually I think I was at 20-25psi at the gun. I was using a crappy cheap-o to lay down the primer and I wasnt getting much of a pattern....more of a small stream. I tried adjusting, but it didnt do much at all. That would account for the dry second fender. I am just glad I have a more powerful air compressor this time around....one more useful for painting.
Duesey
11-17-2005, 12:13 PM
If you spray at different humidity levels and slight variances in mix ratio will yield the two different style finishes that your getting. Both are acceptable for primers. I've been using a sharpe finex for primers and it's the best bang for the money I've came across. I'm confident that with a smaller tip my sharpe primer gun would spray base/clear very good. May not be Sata quality but in a clearcoat that has been blocked and rubbed you couldn't tell what gun was used.
JoshStratton
11-17-2005, 12:34 PM
I used to have a a Sharpe gun. I bought it VERY cheap as a remanufactured gun direct from the company. I used it once and then sold it. Maybe it is time I give them a call again.
BRIAN
11-17-2005, 05:19 PM
You probably started with a clean gun and ended up with a closed up tip from spraying the primer causing the small pattern and dry type spray. By the way there are 2 hardeners for DPLF. go with the one that takes 20-30 min to activate. Better adhesion by far.
JoshStratton
11-17-2005, 05:44 PM
That is probably very true. I tried to get it clean but I may have missed some stuff. Is it possible to clean a gun that hasnt been used in several months and might have dried primer in it? Or after a while is it pointless?
myclone
11-17-2005, 10:21 PM
Once a gun has been sitting that long with primer in it (or any sprayable material for that matter) its pretty tough to get it completely clean. You might try some acetone or methyline chloride (<REALLY nasty stuff) ans soak the metal parts of the gun but do NOT use it on plastics.
If you have access to a small ultra sonic cleaning unit (hint: ebay) then acetone and a bath in the US unit will clean it just like new.
Soaking the parts in pain stripper will work but yeesh its a PIA and messy not to mention lots of time making sure every single molocule of paint stripper is washed off before you can use it again.
CAMAROBOY69
11-18-2005, 04:44 AM
If you use epoxy primer the finish will be quite shiny. Anything else I was going to say is already covered.
Jim Nilsen
11-18-2005, 08:18 AM
When using DP90 epoxy you will have to remember that you have to paint over it within 72hrs 0r 7 days I can't remember which but you have to paint over it within a specified time period or you will have problems with the paint adhereing to it. If it goes past that period of time you have to sand the primer and reprime it.
I primed the car and other parts over a 2 week period of time and then block sanded them all to make sure everything was good. Then I primed the whole car and waited 24 hrs and then blocked the surface one more time and then shot the paint on the 3rd day. So far it looks great 2 yrs later and it really looks a lot better if you block it before you paint over it if it has orange peel. I practiced on a couple of parts and the orange peel will transfer to the paint and make it harder to colorsand without cutting through to the primer.
Goodluck and be patient while trying to go as fast as you can. Being patient and not messing things up takes practice. That damn hose will always somehow try to hit the car or a part if you aren't paying attention :seizure:
Jim Nilsen
JoshStratton
11-18-2005, 08:47 AM
LOL the hose thing I can definately attest to. I am actually doing one part at a time. Strip. Body work. Prime. Move on to the next piece. I am limited to a 2 car garage and cant do it all in stages. I am working on dismanteling the whole car now and will begin the main body work. Hopefully this Spring it will all be in primer and driving around looking like Adams! LOL
StRacerDuke
11-18-2005, 05:05 PM
DP90 is not a primer! It's an epoxy sealer!
Big difference. I've used the stuff a few times and will not bother working with it again. Typically it's used to seal metal and body work if a car is going to sit for a while. What most paint suppliers don't tell you is it doesn't sand worth a crap. The only way I've found to use it and by happy is to strip a car, do all the body repairs and filler work, shoot DP90, let it flash for 20-40 minutes, then lay 2-3 heavy coats of Polyester (SP?) primer over it. You can then let it sit for a long time and come back to final blocking when ever you want. After final blocking I would recomind a medium sealer coat, let it flash for 20-30, then first coat of base, etc.
The DP90 doesn't sand very well at all and the adhesion sucks after it's been sitting for more than 72hrs. If it's been a week and you really care about the paint job I would sand it off and start again. It's not worth spending all that time and taking the risk of having a crapy paint job.
My suggestion: (I've painted a half dozen cars in our shop and throught trial and error figured out what works best for me)
Body work until it is almost perfect, DP90 w/ 30 minute flash, tack it, then 2 coats of evercoat G2 primer. Set aside and go to next panel. Make sure your using at least a 1.7 or higher tip with the primer because you don't want to dry spray it.
Come spring (or when ever you get around to it) you can guide coat and start loosing your finger prints. Guide coat, 220 paper, then 400, with re-priming if burn through.
Just my 2 cents. Hope this helps.
tbair
11-18-2005, 06:13 PM
Dp-90 is a non sandable epoxy primer used to seal bare metal. Dupont changed there mix formula in the past 6-8 months. from 1to1 tp 2to1 if your using a gun with a tip smaller than 1.8 its not going to lay as smooth. but thats not a problem if you have a gravity feed gun bump you pressure up a bit to 40 psi with the trigger pulled if your still not happy with the way it looks. use a little less primer and a little more reducer to thin it out just a little. let it set for a couple of hours and use 1140s uro(Dupont) primer surfacer this is a high build primer that you use to block. if your doing the whole car use 1130 reducer not the 1135 it sets to quick,actavater is 1125. hope this helps,Tim
Jim Nilsen
11-18-2005, 10:35 PM
I went out and looked at my records and I used the DP90 to seal my car and then used DP48LF white epoxy primer which is sandable according to the paint supplier I used. You don't have to sand it if you don't want to and in most cases they don't recommend that you do, but in my case since I was trying to save on paint and it was yellow ,they said as long as I painted over it in 72 hours hours it would be good.
Just so it is more clear as to what I did and why. It takes a considerable amount more of yellow to cover a car than most colors and to make sure it was going to be as bright as possible I used a white primer,grey primer will make yellow get a greenish tint to it if you block the color out and get too thin. So to keep the cost down and not have to buy any more paint than necessary and to get the look I wanted it is the only way the paint shop said I could probably get away with it. It worked out well and was a lot of work in a short period of time. You really have to kick butt and sand for hours to beat the deadline of 72 hrs. I waited for 24hrs to let the DP48 to setup or it is a pita to not tear instead of sand smooth but it can be done and the difference in the final paint is worth the effort. I used at least 1 gallon less in yellow paint and the color sanding was much easier from the experiment I did on the spare lower valance panel I had laying around.
So I hope this clears up some questions that may have come up about what I did.
Everyone that has seen my paint have been impressed about how it came out for being only the 3rd time I had ever painted a car.
It was a lot of work and I don't know if I would want to do it again but the thought of paying 6k for someone else to do it would probably scare me right back to the paint gun again and wearing my fingers out sanding and prepping.
Jim Nilsen
JoshStratton
11-19-2005, 05:46 AM
Let me ask this. Since the car is going to be without paint for a while and I still hope to drive it, would it be ok if I spray the car in DP90, drive it around in the elements. Then, when it is time to do the paint, strip it all off and do what Jim suggested?
Will it protect the bare metal from the elements in the short term?
manicmechanic
11-19-2005, 08:09 AM
I have been reading an article (series) by Larry Lyles out of Amarillo TX. and has said that PPG has changed their procedure's on rust protection to a 3 step process. It is going to bare metal and doing and hammer and dolly work, but not plastic then covering the car, panel etc. in PPG DP74LF epoxy primer in 2 wet coats w/ 10-15 minutes between them. Allow 24 Hrs to cure and then scuff w/180 grit to apply plastic at this time. if you go back to bare metal while working the plastic you have to recover it W/ the DP74LF. It mixes 2.1 with DP402LF catalyst. If anybody wants a copy of the article I can email it to them.
Jim Nilsen
11-19-2005, 09:09 AM
Hey Josh, I don't see any reason you couldn't put on the epoxy primer and then drive around for a term and then just go back and sand it down and clean up anything that started to cause problems. Taking it all off would be a waste IMHO of time and good protection along with a bunch of money. DP epoxy isn't cheap.
The best thing is to ask the person you are buying your paint from is what the body shops are doing along with the other amature paint guys. Like was just stated,PPG has just changed again on what to do. When I was doing my car the DP primer had lead in it to start with and then when the beginning of the year changed it went to the LF which is lead free. So all of my main shell,doors and trunk lid have lead primer on it and my hood and front fenders have LF.
I can see why PPG changed their way of doing things because people like me tried a few different ways to do it more than likely and have had excellent results.
Just remember to follow the directions for mixing and temp, epoxy really does get sensitive to temp for best results even though it is rather forgiving compared to other primers.
A few tips that helped me were to use a coil hose and make a heavy and I mean heavy item with a hook to move around the car with to hook the hose on along with a few hooks in the ceiling and on the walls. You can then move around the car and not have the hose dragging and getting close to the car. Also buy a couple of filters that go right at the gun for moisture control, without a drying system for your air moisture can creep up on you when you least expect it and it will really mess things up. I put one of those plastic drop covers on the floor so I didn't have to worry about dust and cleaning up overspray,make sure you use a new one each time or the dried primer or paint will flake off on to your car when you least expect. I tried wetting the floor on a previous paint job once and all it did was create a bigger mess. Wear a mask that is approved for everything,don't be cheap or you will cause brain damage to yourself along with respiratory problems that might not be noticable but will be there just the same. Get as much lighting on the car as possible,especially down below at the rockers. It is very hard to see down that low without a lot of experience and you will miss things if you don't have enough light on it all.
Have fun,be patient,spend time before you mix and look over the car and imagine yourself going through the whole process and go over a check list to make sure you didn't forget something like tacking the dust off of the car because you got excited. Those few minutes of meditation before you start will help you relax and not forget to srpay areas that need extra paint during the color sanding process. Always do the edges first and then go back and do them again,they never seem to get enough paint. Remember that runs are better than not enough paint but don't sag the paint or it is really bad.
Goodluck, Jim Nilsen
StRacerDuke
11-19-2005, 10:57 AM
From what I hear DP90 is fine to seal the car and drive it around. I don't think you'll have any issues with it. I have heard that it doesn't like the sun's UV light but I can't confirm that. Regardless I don't think it's a problem.
Don't worry if you screw up at all. It's a learning experience. It took me 3 attempts in a row to get my first paint job right :). It sucked but I learned more in screwing up than I could have paid a pro to each me.
Gordz32
11-21-2005, 06:25 AM
Hey you can always tint the primer if your painting the car one color, just a side note, I agree wit hyou guys on the sealer , then primer then sand then seal. Remember your prep is the hard part, Laying the base/clear is cake!
Gordz32
11-21-2005, 06:27 AM
Hey you can always tint the primer if your painting the car one color, just a side note, I agree wit you guys on the sealer , then primer then sand then seal. Remember your prep is the hard part, Laying the base/clear is cake!
JoshStratton
11-21-2005, 07:18 AM
Thanks for all of the excellent posts and ideas! I really appreciate them and will definately be incorporating a lot of them into my job.
Why is it that when a car is in a bare shell, people still mask off? What does that accomplish? Just prevent over spray?
Duesey
11-21-2005, 09:14 AM
If you guys really want an exceptional epoxy primer then try Valspar. They have a DTM high build epoxy primer that doubles as a sealer with the proper reduction. I use it entirely without any of the soft/high shrinkage build polyester primers. It likes a couple weeks before sanding which is smart for any primer. I've was a DP40 epoxy guys until they pulled the plug on it 5years ago or so. I've tried numerous products since then but I really like this stuff. The price is good also, I think it's around 140 or so for a sprayable gallon. I was turned onto the stuff from John Weeler who makes the adjust flex sanders. Which are the best sanding blocks on the market by a long shot. Only downfall is I don't have a dealer near me so I have to pay truck freight but it's still worth it.
