View Full Version : Third-Gem GTA wheels
TurboSteve
01-05-2017, 04:20 PM
Hi,
I did a couple of searches but didn't turn up anything so i thought i would ask if anyone knows whether or not a third-gen GTA 16x8 wheel will fit on a first gen F-body with sick suspension? I just need to roll the car around on something, and that's all i can find on Craigslist locally.
Steve
TurboSteve
01-05-2017, 04:34 PM
Well, i just found pictures of my '67 with them on, so i suspect they will fit a '69 without hitting. It's been 20-plus years since i had that car, so i couldn't remember for sure.
T_Raven
01-05-2017, 07:41 PM
I've rolled my 67 around on my GTA wheels before.
If you just want something cheap to roll the car around on, I like to get donut spare tires from the junk yard. They are usually around $10 each at a pick n pull type yard.
TurboSteve
01-06-2017, 09:29 AM
That would be much cheaper and i didn't think about that. Thanks.
mean buzzen half dozen
01-06-2017, 10:30 AM
They will fit.
IIRC you would use the front wheels for the rear and the rear wheels fit in the front. Or am I thinking that is how I used my 88 IROC wheels? Anyways, the IROC's are 16X8 also.
T_Raven
01-07-2017, 04:20 AM
I keep a couple sets on hand to roll stuff around on. I put a set on this Camaro when I sold it. 3rd and 4th gen f-bodies have them in the right bolt pattern, but I have some that are 5x4.5 and I just elongated the holes with a die grinder. If they don't clear your brakes, some will fit better backwards.
https://static1.pt-content.com/images/pt/2017/01/5a259e-1.jpg
Skip Fix
01-07-2017, 11:28 AM
The "fronts" are about a zero offset. "Rears maybe 3/4-1" in if I remember right. Ran them with 255-50-16 on my second gen for years with BFG R shaved autocross tires
Classic Industries repops them and probably has exact specs.
TurboSteve
05-06-2017, 07:13 AM
139965
- - - Updated - - -
i forgot to update. Sorry about that. Getting started on some quick body work and a cheap paint job next.
CliffsBlueCamaro
05-06-2017, 07:44 AM
Ditch those uber-tall center caps, slam the stance, and those would look GREAT just as they are!
F-Body International
05-08-2017, 08:38 AM
Agreed but I'm not sure if losing the center caps is possible up front due to the wheel bearings. Those "show" caps usually cover the real nut and cap.
1989GTA
05-08-2017, 09:10 AM
I agree. I think they will look great on your car.
