View Full Version : Vacuum at max rpm question - EFI setup
RSX302
01-02-2017, 05:40 PM
Understandably one would want little to no vacuum at max rpm for maximum horsepower.
My question is, if I have 1.78inhg (95kpa) at max rpm, what kind of hp am I leaving on the table and would it be worth going bigger on my intake setup. Start seeing vacuum at 4000rpm. 100kpa below 4k.
Dyno'd my new LS9 434 (4.155x4.0), AFR 245 head, Super Vic Single Plane, 1200cfm 4bbl TB.
635hp / 579tq
andrewb70
01-03-2017, 07:24 AM
I am confused. How can you have more than 100kPa below 4000 rpm? What's your kPa at idle?
RSX302
01-03-2017, 08:56 AM
Hi Andrew
This is on a dyno at WOT. Where i'm located, atmosphere is 101.3kpa (14.7)
Theoretically with absolutely no intake/throttle body restrictions, I should see 101kpa throughout the rpm range at WOT.
andrewb70
01-03-2017, 09:36 AM
Hi Andrew
This makes sense now. My pure wild guess is that you might be giving up 10hp....this is purely a guess.
On the other hand, maybe even less. On my 5.3L with my bug catcher and dual 87mm TBs, I never hit above 95kPa when I am driving. This all of course depends on the DA at any given moment.
RSX302
01-03-2017, 08:00 PM
Twin 87mm TB's...damn
I was expecting around 650hp (565rwhp) with this engine as I've seen similar setups run 675hp. Although the compared engine has a FAST intake with a 102mm TB, open exhaust and no accessories.(on engine dyno)
10-15hp would make sense from my restricted TB to the FAST intake and 102mm TB. I'm thinking the open headers and no accessories is probably worth the other 25hp on the engine dyno.
Since I had the 1200cfm 4barrel throttle body, I figured that would be enough. After doing the math, (1.75" x 4) I find that it only comes to 77.7mm. dOh!!
Thats as big as a 4150 carb flange 4 barrel has unless I adapt something different (4500 flange or 102mm big bore)
I went with this set-up since I already had most everything from the turbo system I removed. Cost effective and saved 200lbs off the nose. :twothumbs
135651
135656
https://youtu.be/cVe7n3MM-_s
71RS/SS396
01-10-2017, 04:21 AM
More air will help it, but I wouldn't go to a Fast 102, they choke big inch engines up top. I initially tried one on my 450" engine and it wouldn't pull past 6400 rpm, when I went to the Ozmo twin tb intake the engine picked up 50 hp and pulled to 7,800 rpm. I would try an adapter with a 4500 tb.
Fast 102
https://static1.pt-content.com/images/pt/2017/01/newdynosheet-1.jpg (http://s1009.photobucket.com/user/tmackg71/media/newdynosheet.jpg.html)
Ozmo twin tb intake, ignore the vacuum numbers it has a 5 stage dry sump that's pulling 15" on the crankcase.
https://static1.pt-content.com/images/pt/2014/07/450ls-1.jpg (http://s1009.photobucket.com/user/tmackg71/media/450ls.jpg.html)
RSX302
01-17-2017, 09:39 PM
Holy smokes!! Ozmo is a serious piece of jewelry. That's an impressive hp gain you got and a ton of rpm!!
I was looking at getting a 4500tb with an adapter but then got a deal on a Holley 105mm.
Was doing the math on a 4150 flange and found the opening to be about 12.5-13sqin. The 105mm is 13.4sqin and 4500tb is 15.9sqin. I think to do the 4500tb justice I would need a 4500 manifold. Unfortunately the only one I found there for a cathedral port is Mast. Now hood clearance issues.
The 105mm Holley looked like it was made for the 4150 flange. Lol
Straight shot!
136208
136209
71RS/SS396
01-18-2017, 04:56 AM
I think you might be surprised how well the 4500 will work even with the adapter. The problem with that Holley mounted like that is you have to put a turn in the intake directly above it which is going to disturb the airflow and it will also impact the the impulse waves. I experimented with several different air intake tubes when I had my engine on the dyno, I was stunned at how adverse the effect of the bends were to power. I had a tube with just one 45* bend in it and it knocked 25 horsepower out it so I ultimately put the filters directly on the tb's since it made the most power that way.
andrewb70
01-18-2017, 07:21 AM
Holley makes a 4500 series 2000 cam throttle body that is fairly short. Maybe combine that with the Mast intake and see what the stack up height is...Mast also makes a ring that will mount over a 4" TB and allow the use of a regular air cleaner without doing an elbow.
RSX302
01-18-2017, 07:32 AM
Actually I'm going to try and use/modify my air cleaner setup to keep it looking old school.
Sorry for the sideways pictures, uploading from my iPhone.
136210
136211
RSX302
01-18-2017, 07:36 AM
Cool, I'll check out the air cleaner adapter.
RSX302
01-18-2017, 07:50 AM
But before I finalize a direction, I need to get out and tune. I'll also run it back over to the dyno and see if this is how it will stay. I'll report back with the numbers. Might be the moment Tim says "See, I told you so" Lol
I'm hearing airflow on the AFR LSX245 heads supports up to 700hp, so I figure if I can get anything close to that, I'll be happy.
71RS/SS396
01-18-2017, 05:30 PM
Do a dyno pull with and without the air filter and with the hood closed. I would be curious to see the results.
RSX302
01-19-2017, 08:36 PM
Will do..
Update...
I did a quick drive around without filter. Drove very nice. Low rpm throttle/tip-in had more resolution than the Accel 4bbl TB. I purchased the Holley 105mm with the low rpm taper. I was pleasantly surprised how well it worked.
On to the power run data log...
As soon as I opened up in 3rd gear getting on the freeway, my knock sensors immediately kicked in and retarded timing. Never had this issue with the smaller TB.
Drove around a little more then tried again. This time starting in 2nd gear. Pulled hard in 2nd to 6500 without timing retard. Shifted to 3rd, then boom, knock sensor timing retard again.
Brought it home to investigate data log files. Sure enough, 10deg timing retard on knock.
Pulled spark plugs and they looked hot but no sign of detonation. I found out that I screwed up and put the wrong heat range in. dOh..had NGK TR5's..I change to TR7's.
Fuel had a splash of VP110 in the tank. I figure mix is 95oct. Should be fine for my setup but I will put 5gals of 100oct in and try again.
I'm thinking this is a positive sign of power!!
The good data I recorded in 2nd gear shows 6500rpm, 24deg timing, 12.8:1A/F, 275lbs/hr fuel. (685ish hp) Fuel flow with the smaller TB was 255lbs/hr.(635hp)
Now that it started raining in Calif, I'll need to wait to test again. Looks promising.
BTW, I have the Holley HP FI system
garvir
03-26-2017, 08:24 AM
you mentioned using a paper filter, that will cost you around 5 hp... a guy from K&N spotted my paper filter (14"x3") on my small block and claimed it was costing me 10 hp or more. because it was more restictive than the K&N.
chpr1972
04-05-2017, 06:53 AM
RSX302, you are running a knock sensor on your motor. I have a Holly HP_EFI and was told I could not run a knock sensor because of different harmonics than stock. BBC 489 10:1 230/ 236 510/ 520 Comp cam with early closed chambered heads and a tunnel ram with 2 4bbl TPI. Is it possible for an amateur?
RSX302
05-03-2017, 07:18 PM
I apologize for taking so long. I have everything complete and I'm happy with the result. I used the Spectre air intake (aka K&N..lol)
139905
139906
139907
139908
139909
RSX302
05-03-2017, 07:47 PM
Funny that you mention knock sensors. :pat:
Yes, I'm running them and it's driving me nuts!!
I can get them to work, then they kick in out of the blue. Kill'n me!!
Before I installed the bigger throttle body, never an issue.
I've tried 114oct fuel and still kicked in. Has to be false knock.
Perfectly fine in 2nd gear with no knock retard, pulls hard. As soon as I shift, instant knock retard. I'm still tuning and getting everything dialed, but it's hard to do when the knock sensors are so intermittent. Tip in fuel data log is good. Set at 12.7:1 af at WOT.
If I slow roll the throttle in 3rd, I can avoid knock retard.
I thought I would start changing the freq and sensitivity to see if that helps. I've tried 5.5khz @ 50 sensitivity and 9.5khz @ 35 sensitivity. Knock hits 100 instantly. This weekend I was going to try bouncing around to see what affects, if any.
If all else fails, I will turn them off. Plugs look clean with absolutely no sign of detonation.
RSX302
05-07-2017, 12:11 PM
Knock sensor parameter set to 5.5khz @ 10 sensitivity. Knock level data log recorded between 10-50. Seems that this may work.
Now time to schedule a dyno session.
RSX302
05-13-2017, 12:35 PM
Results are in!!!
Throttle body was good for ~20hp
No noticeable difference in power with and without hood and air cleaner.
Accel DFI 1200cfm TB (27deg timing, 95-96kpa)
552rwhp
504rwtq
Holley 105mm TB (29deg timing, 98-99kpa)
573rwhp
518rwtq
andrewb70
05-13-2017, 05:05 PM
Are you sure it wasn't the extra two degrees of timing?
RSX302
05-14-2017, 08:24 AM
I started the dyno session down at 24-25deg just to see how the timing profile responds. This lower timing netted 557rwhp (+5hp from tb change)
Biggest gain was upping to 27 degrees which netted 570rwhp. (+18hp)
Increasing to 29-30 was only worth about 3-4hp which brought me to the peek of 573.5hp (+21hp).
Noticed that it still has a little more RPM in it. Computer data log shows rev limiter cutting at 6800 (set at 7000). But this is how it was set from the last session to be apples to apples. Not sure if I want to spin over 7K.
Comparison from the previous graph shows it definitely helped above 6K
140231
https://youtu.be/SfMIaxk9BgY
RSX302
05-16-2017, 07:24 AM
As Tim (71RS/SS396) was saying, my combo would probably greatly benefit from the Ozmo twin intake above 5000rpm. Not sure if I ready to swallow that $$$$ pill. Ti intake valves and better springs would need to come with it. :hand:
MonzaRacer
06-20-2017, 05:52 PM
635hp / 579tq
Ok so your seeing a slight amount of vacuum at WOT? Wow so just what do expect to see? An N/A engine still sees a bit of vacuum, also the port you use may also some reading due to air flowing past the port.
If you want more power to get past 100% VE you will need a supercharger or turbo. With a 600+ hp engine just drive the dang thing and be happy. I mean it's not like your giving up anything from what I see and it's not like a couple HP would make difference.
I mean if you are that desperate for power add turbo.
RSX302
06-21-2017, 09:48 AM
Hi Lee,
I was thinking I should be close to 100kpa for no restriction manifold. I was able to reduce the manifold pressure from 95-96kpa to 97-98kpa at WOT with the throttle body change. This netted approx 20hp for me on my setup. (552rwhp to 573rwhp)
I switched my engine setup from the previous twin turbo 600rwhp to this new N/A 573rwhp engine. With that, I removed 200lbs off the nose and so far loving it. Power/weight ratio is the same as before at 5.6:1.(w/driver). Handling is much better as a result which I was looking for.
My new engine combo max is figured to be 700fwhp so I figure whatever I can do (relatively inexpensive) to get close to that number, I'm happy. I'm sure if I use the Ozmo twin intake and spin to 7500, that number is achievable. but that goes a little beyond relatively inexpensive. Lol..that last 40hp is very expensive.
RSX302
06-21-2017, 12:54 PM
BTW, I was going to look into self port and polish the manifold to see if I can't find a little more. Still on the platform of relatively inexpensive.:twothumbs
