View Full Version : Fuel line options for EFI conversion?
downl50
01-01-2017, 05:09 PM
I have a 427 SBC, ~550hp going into a '70 Chevelle, planning on using a repro tank with either Aeromotive or Vaporworx 5th Gen pump. I'm planning on using the Holley Sniper EFI though haven't seen a ton of feedback on it yet.
Holley Sniper a reasonable option for this application?
What are recommended options for fuel line?
Option 1: stock 3/8 pre-bent and adapting 6AN on either end (Classic tube or inline tubing)
Option 2: Late model OEM nylon http://www.techafx.com/content/6-flatwrap-ss-braided-teflon%C2%AE-hose-20-length
Option 3: Holley kit with vapor guard hose: https://www.holley.com/products/plumbing_an_fittings_and_hose/hose/vapor_guard_hose/
Option 4: custom bend some stainless steel
It seems #3 would the easiest, $200 including a pump I wouldn't need but also looking for a durable long-term solution.
Thanks!
dhutton
01-01-2017, 05:36 PM
I used 1 and Vapor Guard hose on the ends FWIW.
Don
jdbr1
01-01-2017, 05:37 PM
Im usein the fiitech setup had a 100 rebate,$995 - 100 rebate, tanks inc efi tank was $210, bolt in pump $210 +sender plan on using fragola premade steel braids PTFE line ordered through Jegs
XLexusTech
01-01-2017, 06:43 PM
PTFE I used Fragola
downl50
01-02-2017, 10:47 AM
Thanks for the feedback -- any raw fuel smell with the braided lines?
dhutton
01-02-2017, 11:52 AM
You need carbon impregnated PTFE lines to avoid the fuel smell.
Don
oleyeller
01-02-2017, 01:53 PM
I went with option #1. One piece back to front, no joints no leaks, and it fits. Two 37 degree flares and off you go.
camrat68
01-02-2017, 02:01 PM
Inline Tube can put FI ends on their pre-bent stainless lines also if you want. At least they did for me.
Jim
andrewb70
01-03-2017, 07:27 AM
Option #1 and use PTFE for the short flexible runs on either end. Here is how you mate AN fittings to hardline.
http://www.youtube.com/watch?v=46hFmkTGGV8
CarlC
01-03-2017, 09:46 AM
If a stock stainless tube + PTFE flexible ends are used no additional filters are needed for the VaporWorx setup.
I agree with the use of the stock hardlines for ease of installation. Sometimes the hard part is straightening out the bend from shipping.
TheJDMan
01-03-2017, 10:20 AM
I also used the stock hard line and installed AN ends on it. But if you are running a proper return system you will need to run a second line. I used Aeroquip AQP line and have had no fuel smell in the two years since install. I actually use the hard line as the return and the new AQP line is my supply.
downl50
01-04-2017, 07:19 PM
Awesome,thanks for all the feedback! I've heard aluminum is easy to work with but not ideal for street cars due to longevity. Others have said it lasts plenty long enough -- any thoughts on this?
downl50
01-04-2017, 08:15 PM
This may be the answer: http://www.speedwaymotors.com/Aluminum-Fuel-Line-3-8-Inch-OD,1633.html
"The main issue when dealing with aluminum tubing (or any aluminum for that matter) is that it “work hardens” when it flexes, which can lead to cracks. It is important that the hard line is isolated from vibration and movement.
Clamp the tubing securely with rubber coated clamps (Adel clamps) and use bulkhead fittings where the tubing attaches to the flex line. Never run the tubing directly to the engine without a flexible hose section. If installed properly, aluminum tubing is safe and durable."
Jk918
04-06-2017, 06:29 PM
Can u hook the hard line straight to the flex line, without flaring it or incorporating AN feelings? Looking to use Mostly hard line with flex at carb and tank, have short pieces of efi flex hose & efi hose clamps and wasn't sure if hard line would need some type of flare to prevent leaks?
andrewb70
04-07-2017, 06:45 AM
So you have a low pressure carbureted fuel system?
Jk918
04-07-2017, 12:46 PM
No actually in process of switching to FItech on my SBC, was hoping I could use the stock hard line with short pieces of efi line and efi clamps at the tank and FI unit, and not have the additional expense of AN fittings. Basically looking to hook up the short efi hose with clamps but wasn't sure if pressure of efi pump would be to much for clamps vs AN fittings
TheJDMan
04-09-2017, 05:01 PM
I suppose you could just slide the hose over the line and clamp it but it would look like crap. I would use these AN to tube compression fittings then use a normal AN hose to connect the ends.
https://www.summitracing.com/parts/fra-892006bl/overview/
Jk918
04-10-2017, 06:39 PM
Thanks that looks like it would fit my needs
Kenova
04-12-2017, 07:03 PM
X 2!
I used aluminum line and Fragola PTFE line on my Nova. Next time I have to do a long run of hard line I think I'll give the NiCop line a try.
That nifty little tool that Andrew demonstrated is a hand full of Aces. I have one and it doesn't stay in the garage. When it's not in use it has a special spot in my basement storeroom. Some tools are just that special. LOL
Ken
67 455 Bird ragtop
05-11-2017, 02:37 PM
WIll these work with Steel, alum, or stainless ??
andrewb70
05-11-2017, 02:40 PM
Probably...although Swegelok (SP) makes really nice stainless compression fittings. I would use those.
ULTM8Z
05-13-2017, 10:03 AM
I've been running PTFE front to back for going on 10 years now. Never one problem.
cdrod
05-14-2017, 04:53 AM
Downl50:
Some '70 A-body cars have a 2-piece fuel line the connects with a short section of rubber hose at the passenger side body mount (see pics). This section of hose should at the very least be upgraded to a barrier-type hose, or replaced with braided or something that can handle the ~60psi pressure from an EFI fuel pump. To minimize connections (i.e. possible leak points) I'm planning to use a compression fitting at this point and run -6AN brained line through the frame rail all the way to the throttle body.
140225140226
Tsunami
05-13-2019, 06:49 AM
Used 3/8 Nicop supply and return fuel lines on my 40 Ford build. great product to work with!
WildCherry66
05-13-2019, 07:22 AM
I have Nicopp that I plan to use for my pressure and return lines. What kind of fittings are those in the last photo? I was planning on using Earl’s VaporGuard hose and barb to 1/4 NPT fittings with their stainless band clamps to connect to my tank bulkhead, in and out of my inline filter and to my Sniper EFI to allow some flex.
andrewb70
05-13-2019, 07:29 AM
Chris,
I made a video a while ago that goes through all the details of using NiCopp lines and AN fittings:
http://www.youtube.com/watch?v=46hFmkTGGV8&t=2s
Tsunami
05-13-2019, 10:07 AM
I used 3/8 Nicop for the fuel supply and return lines. The fittings are:
Russell 66575 #6 Tube nut
Russell 660651 Endura -AN6 Tube Sleeve
Russell 660353 Union Adapters (-AN6 to -AN6)
Hope this helps
Alponcho
05-27-2019, 11:06 AM
Up to what HP will factory 3/8" lines work? My plan was to run a single 3/8" pre-bent hard line (with added AN fittings) but have been told I need 1/2" for my application (Pontiac 535, Fast EZ EFI 2.0, Rick's tank, ZL1 pump, Vaporworx).
andrewb70
05-27-2019, 11:33 AM
550-600hp at the crank.
max69chevelle
07-03-2019, 07:17 PM
Expensive but I used PTFE lines and fittings from Pegasus Racing. The bend radius is great on them.
Alponcho
07-05-2019, 02:17 PM
The selection of 1/2" Nicopp lines seems pretty limited...any recommendations for a good source/brand?
Alponcho I just got done running this line https://www.summitracing.com/parts/sum-220220-25 and was really pleased. I used this on the ends https://www.summitracing.com/parts/sum-2200078b/overview/ and then got all the rest of the fittings and PTFE hose from Frozen Boosted.http://www.frozenboost.com/stainless-steel-teflon-fuel-lines/?osCsid=93607e686d345864b0fb7d4151d406e9
badazz81z28
07-22-2019, 03:19 PM
I run 3/8" with the vaporworks and ZL1 pump...LS 427/ 550 RWHP. No issues and I was living at 7000rpms at the road course. I think you need some massive power to require 1/2" fuel lines...The engine doesnt require that much fuel for normal driving.
BTW....The ZL1 pump has a 3/8" outlet.
