View Full Version : Can a Sub Woofer be used as a Woofer? 8" Audio Pipe, confused...
pitts64
12-30-2016, 02:36 PM
1234
gordonquixote
12-30-2016, 03:25 PM
Probably would be fine in a proper enclosure with a proper amp. An old scool Sony XEC505 with bass gain would do wonders for it.
I assume you are going to use a crossover and not play it full range?
That being said....it is just an 8" speaker.
pitts64
12-30-2016, 06:38 PM
5678
andrewb70
12-31-2016, 12:35 PM
Yes, I'm using an Audio Pipe crossover. The woofer will be mounted in the wooden cabinet... I also have a pair of tweeters were the old 4 x 10 speaker was.. I removed all the hvac from the car, so I have a lot of room under the dash..
Thank you!!
135511
135512
135513
135514
Dude...You're fired...
Don't use those wire twisty things in a car.
minendrews68
12-31-2016, 01:31 PM
What I'm sayin'.......
raustinss
12-31-2016, 02:27 PM
Yep I agree with the other fellas say those are a bumpy road away from a dash fire or blown fuses ....no regardless of the amps or speakers .....get a real head unit ...if the amp is getting "dirty signal" it won't matter what amp you have . Having said that a cross over is highly recommended. Once you have those things figured out then worry about speakers . Any speaker will play basically any sound (loosely meant for you fancy guy ) using a cross over to funnel a certain frequency range that matches what said speaker performs best at will obviously provide the best sound
pitts64
12-31-2016, 03:50 PM
9876
pitts64
02-02-2017, 07:48 AM
5432
andrewb70
02-02-2017, 05:44 PM
Can you elaborate on all the drivers and what they actually do?
