View Full Version : 4L60E Crossmember mounting location from centerline
RT66ProTouring
12-30-2016, 01:16 PM
I'm looking for a dimension of a 4L60E. I need the vertical distance from the centerline to the crossmember mount. I'm trying to determine if my planned crossmember will work.
Anyone have one out so you can get a measurement?
Craig@Bowler
02-01-2017, 11:00 AM
If you haven't already figured this measurement out. I had a newer unit with the removable bellhousing here and measured 2.5" from the trans mount surface to the centerline of the output shaft.
