View Full Version : Battery cable through firewall options
DT69Cam
12-26-2016, 06:16 AM
Are you guys using a bulkhead connector at the firewall to run the positive battery cable through or just a grommet ?? I'm not sure I like the idea of a LIVE cable connection at firewall using a bulkhead connector. I was also considering just a grommet and run the pos cable to the starter. I hope those caps on the bulkhead connector will prevent accidental contact.
Twentyover
12-26-2016, 07:13 AM
Go to someplace like Aircraft Soruce and get cable end covers. They are like a flexible short spark plug boot to cover exposed wire terminals.
DT69Cam
12-26-2016, 07:37 AM
Thank you.
gray86hach
12-26-2016, 01:26 PM
CLaZoYTmktECFUQdaQodNGgO9Q
I have used these.
Tim
gray86hach
12-26-2016, 01:28 PM
https://m.summitracing.com/parts/aaf-all76138?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-allstar-performance&gclid=CLaZoYTmktECFUQdaQodNGgO9Q
DT69Cam
12-26-2016, 01:53 PM
Thanks.
Richard454
12-26-2016, 03:50 PM
Here you go- a neat solution-cost maybe $5 at your local pull-a-part
Not only to hook up your starter but also a terminal block for a couple other connections-
Mounted on the firewall- look at the mid 90's BMWs - the big ones 5 & 7 series
https://static1.pt-content.com/images/pt/2016/12/P1010556-1.jpg
Cover on-
https://static1.pt-content.com/images/pt/2016/12/P1010557-1.jpg
parsonsj
12-26-2016, 04:03 PM
Yes, I'd reconsider on the bulkhead. They are damn useful for lots of things.
SS Performance
12-26-2016, 04:32 PM
I have used these many times with great success
https://www.waytekwire.com/item/47210/EATON-s-Bussmann-Series-C5898-Junction-Block-/
icemanrd19
12-26-2016, 06:06 PM
I used the same bulkheads as dse.
DT69Cam
12-26-2016, 08:20 PM
Thanks everyone.
TheJDMan
12-31-2016, 06:55 PM
I have been running this bulkhead connector from AllStar and have been very satisfied.
https://www.summitracing.com/parts/aaf-all76142
Chad-1stGen
12-31-2016, 11:13 PM
I'd also consider not leaving the main battery cable live. Use a Ford solenoid or equivalent so it's live only during cranking.
csouth
01-01-2017, 10:27 AM
x2 on both of these. I have the All Star Performance bulkhead and a Ford solenoid, both work great.
CapSS92
01-01-2017, 11:27 PM
I've used the heavy duty rubber grommets successfully. I can't remember the brand but I'll attach some links. I've used them through frames and firewalls with no problems and they've stood up well. I'll look for a brand and part number tomorrow.
https://www.lectriclimited.com/media/wysiwyg/battery_cables/bc-battery_cables-ground_straps.jpg
http://www.steelerubber.com/battery-cable-grommet-40-0322-21
70 Chevelle
01-02-2017, 01:40 PM
Another option
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjusu-HtqTRAhUWgbMKHd9XAJIYABAI&ohost=www.google.com&cid=CAASJORoyh6OgNCWHCU4BywC8yZd02ns3PiacY8W-_IJIV1P04ffdg&sig=AOD64_2DnlFIoGsc8lGx0V9qzhqrsazNlg&ctype=5&q=&ved=0ahUKEwijxOyHtqTRAhVDMSYKHSPlADcQwg8IHA&adurl=
DT69Cam
01-03-2017, 06:26 AM
Another option
This is exactly what I will be using. Damn thing is huge though. Hope the engine is not too far back with the holley mounts and LS3.
DT69Cam
01-03-2017, 06:30 AM
The battery grommet is another option. However, I'm using 1/0 Batt cable. Actually, I think the 1/0 gauge cable is 5/8's. I will have to double check. Thx.
cpd004
01-03-2017, 09:43 AM
Another option
I'm using this with no problems so far. I may switch to the bulk head since I'm redoing a few things. I currently pull power at the starter for the Speartech harness. It would clean things up just a bit if it was on the firewall.
dhutton
01-03-2017, 10:17 AM
Not sure why guys don't like the bulkhead. Even DSE uses them and supplies them with their battery relocation kit. Put a protective cap on it and you are good to go.
Also curious if DSE uses a relay for the starter cable. I am pretty sure GM does not use one for the trunk mounted batteries in the 5th gen Camaros.
Don
TheJDMan
01-03-2017, 10:30 AM
I have contemplated using a relay on the main 12v cable but instead I installed a 250amp circuit breaker back in the trunk next to the battery so that it will trip if the cable shorts. I also have a master disconnect switch mounted in the trunk so I can kill power when the car is being stored.
cpd004
01-03-2017, 05:41 PM
I too, am running a breaker in the trunk. No solenoid. My G8 has a constant live feed from the trunk as well. The only reason I didn't initially go with the bulk head is that I didn't have one on hand but did have the pass through linked above.
Kenova
01-04-2017, 06:02 PM
Another option
I picked up one of these at a local electrical supply store. It eliminated two connections at the fire wall that you would have with a bulkhead connector. It is water tight and holds the cable securely.
Working well so far.
Ken
Rockin Rod
01-04-2017, 06:37 PM
I didn't see it mentioned but I used the Ron Francis bulk head fitting. Didn't want to put that big of a hole in the firewall after all the time spent filling holes, but everything I looked at needed a big ass hole.
DoABarrelRoll
01-16-2017, 07:15 PM
Cover on-
Have a part number?
Chuff
07-29-2020, 02:50 PM
Does any have some more information on the BMW part in the previous post?
After a couple of days of Googling I've had absolutely no luck identifying this BMW part.
Year. Model. Part number. Anything more than just a photo might help.
Anyone?
Thanks.
Chuff.
JustJohn
07-30-2020, 03:51 AM
Here's the E46 firewall pass through. That should get you started.
https://www.ecstuning.com/b-genuine-bmw-parts/positive-terminal-base/61138387540/?gclid=CjwKCAjw34n5BRA9EiwA2u9k35W_tSFkbCsv1A6Aq6R QCrbq3mqDiRfhanLfWG0Sb3BKCmLftSwHCxoCBFkQAvD_BwE
https://www.ecstuning.com/b-genuine-bmw-parts/positive-terminal-base-cover/61138371011/?gclid=CjwKCAjw34n5BRA9EiwA2u9k3548OB7fCnhCuwFMPTR BsYVnonZCl26eYDTNTLKVDSWF6vJm75IjRRoCFBkQAvD_BwE
Anyone?
Thanks.
Chuff.
