desids
12-25-2016, 11:32 PM
I have been lurking here (and the Lateral-G forums) for many years while building out my 69 Camaro, however last year I was able to pick up an All Wheel Drive 1932 Roadster called QuadraDeuce. I'm hoping many of you have seen the car before - I remember reading about it in the magazines 20 years ago. Here is a little history:
Version 1.0
First created in 1995, the QuadraDeuce was the brainchild of Summit Racing Equipment R&D Chief, Mark Stielow, famous for his Pro Touring Camaros. It was initially painted purple and yellow, had a 6-speed transmission and made the rounds in all of the major car magazines such as Hot Rod, Car & Driver, Street Rodder and of course the Summit catalogs.
Version 2.0
Recreated in 2000 by Troy Trepanier of the famous Rad Rides by Troy. The original QuadraDeuce contributed its GMC Syclone front differential and transfer case, front suspension, Corvette ZR-1 rear differential, Harwood fiberglass/carbon fiber body and grille shell insert. The rest of the vehicle was heavily modified or built from scratch to create a whole new look.
Version 3.0
Updated in 2016 by Campbell Auto Restoration, the paint, engine and drivetrain were all retained. Everything else was updated including new interior, leather dash, gauges, soft top, brakes, wheels & tires, headlights, and many changes to the suspension geometry. She has a few nicks and chips, but that iconic paint from version 2.0 is still there.
Some updates specs below:
CHASSIS
Frame: Harwood frame rails stretched to 112" wheelbase
Front Suspension: Pushrod activated A-arm, GMC Syclone differential with custom half-shafts and limited slip
Rear Suspension: C4 Corvette suspension with coil overs, Corvette ZR-1 center section and limited slip
Brakes: Baer four-wheel disc 6 piston calipers (14.0" front and rear)
Wheels and Tires: Budnik Pivot SKO (18"x8" front, 20"x10" rear), Pirelli P Zero tires (245/45R-18 and 285/40R-20)
ENGINE AND TRANSMISSION
Type: Chevy 400 small block bored to 406 cubic inches, 594 HP, 0-60 in 3.2 seconds
Cylinder Heads: Chevy Bowtie 18° aluminum, ported, polished, cc-ed
Induction: Chevy Bowtie 18° aluminum intake modified for electronic fuel injection, 35 lb.-hr. Bosch injectors, Holley ECM
Exhaust: Custom 2" primary headers and dual exhaust with Flowmaster mufflers into single tailpipe tip
Transmission: TH-700-R4 automatic with 3,000 RPM stall converter, built by Rossler Transmission
Other Items: Custom C&R Racing radiator, custom air cleaner by Rad Rides by Troy, custom gas tank by Rick’s Tanks
Engine Built By: John Lingenfelter of Lingenfelter Performance
PAINT AND BODY
Paint: PPG Smoke Charcoal Silver and Wild Cherry
Body Modifications: Hand-built steel hood, aluminum side panels, grille shell, and taillights all by Rad Rides by Troy
Modifications 3.0: Mirrors and headlights by Campbell Auto Restoration
Bodywork By: Warren Lewis at Rad Rides by Troy
Paint By: St. Aubin Auto Body, Manteno, IL
Flames and Graphics By: Bob Thrash, Manteno, IL
INTERIOR
Upholstery: Distressed leather with perforated inserts, custom seat, door panels by Campbell Auto Restoration
Dash: Modified '32 steel, leather covered, notched for speedo by Campbell Auto Restoration
Gauges: Classic Instruments full sweep
Steering Wheel: Budnik Velocity
And here are some recent pictures from its recent outing at the August 2016 Good-Guys in Pleasanton.
Good to meet everyone here,
Desi
https://static1.pt-content.com/images/pt/2016/12/IMG_7067-1.jpg
https://static1.pt-content.com/images/pt/2016/12/IMG_7082-1.jpg
https://static1.pt-content.com/images/pt/2016/12/IMG_7085-1.jpg
https://static1.pt-content.com/images/pt/2016/12/IMG_7072-1.jpg
https://static1.pt-content.com/images/pt/2016/12/IMG_7087-1.jpg
https://static1.pt-content.com/images/pt/2016/12/IMG_1973-1.jpg
Version 1.0
Version 2.0
Version 3.0
CHASSIS
PAINT AND BODY
INTERIOR
Desi
