UMI Performance
12-20-2016, 07:37 AM
Upper and Lower Front A-arms for the 1970-1981 Camaro and Firebird
P/N 26xxxx
Prices starting at $449.99
UMI Performance, Inc. is pleased to release our new 2nd Generation F-body upper and lower a-arms as part of the upcoming total product line for this exciting platform. These arms are perfect for the F-body enthusiast seeking to improve the performance and appearance of their front suspension. The current lower a-arms are available in standard spring bucket configuration or UMI’s coming soon is an extreme performance coilover-only version. Both styles feature caster relocation of the lower ball joint (2 deg and 4 deg respectively) as well as a variety of ball joints (standard and tall) and bushing configurations (polyurethane or Delrin). The upper a-arms are available in standard or extreme performance adjustable versions. The offset cross shaft standard version adds 3 deg caster and uses smooth UMI Delrin bushings. The extreme performance version is adjustable to easily fine tune caster (5 deg over stock) and add camber without excess shims. They pivot on race quality rod ends and can be loaded with standard or tall ball joints to improve camber gain. Available in UMI red or gloss black powder coat. 100% designed, manufactured and raced with pride in the USA.
WEBSITE LINK HERE
(http://umiperformance.com/catalog/index.php?main_page=index&cPath=340_445)
UMI P/N 2651- Polyurethane lower a-arms. 2 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/2651a_LRG-1.jpg
UMI P/N 2652- Delrin bushing lower a-arms. 2 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/2652ab_LRG-1.jpg
UMI P/N 2653 & 2653-1- Delrin bushing upper a-arms, optional taller ball joints. 4-5 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/2653a_LRG-1.jpg
UMI P/N 2656 & 2656-1- Adjustable upper a-arms, optional taller ball joints. 5-6 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/26561abb_LRG-1.jpg
UMI P/N 265153- Polyurethane lower bushings, standard ball joints. 6 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/265153a_LRG-1.jpg
UMI P/N 265253-1- Delrin lower bushings, taller upper ball joints. 6 degrees of caster.
https://static1.pt-content.com/images/pt/2016/12/2652531ab_LRG-1.jpg
UMI P/N 265256-1- Delrin lower bushings, adjustable upper a-arms, taller upper ball joints. 6-8 degrees of caster.
https://static1.pt-content.com/images/pt/2016/11/2652561a_LRG-1.jpg
P/N 26xxxx
WEBSITE LINK HERE
