View Full Version : Dry Sump Tank Location??
BlackdogNY
12-13-2016, 11:06 AM
Engine bay is cluttered...seen plenty of 'race cars' with them mounted behind the driver(front engine cars)...any thoughts/comments or experiences with having tank not under the hood??
Positives...extra capacity...extra cooling...weight dist...away from heat...????
Negatives...cost...weight...complexity...more places to have leaks...????
Engine has been set back 12"+/- if that makes a difference. If its located by engine it would have to be in front of it.
Trying to keep as much weight within wheelbase.
It would be completely sealed from drivers compartment by rear firewall. Hoses would be run in access panel with other fluid/wiring.
Planning stages so lets here what you think.
B&G
sccacuda
12-13-2016, 12:47 PM
Mine will be on the passenger side back seat area, sealed off from the "driver/passenger compartment". It helps moving that weight to the rear/passenger side, in front of the rear axle and low to balance car; battery will be right behind it. Offsetting the driveline also helps. Mines 1-1/2" over to the p-side.
https://static1.pt-content.com/images/pt/2016/12/IMG_1270_zpsfpgkim1x-1.jpg (http://s1060.photobucket.com/user/340cuda/media/IMG_1270_zpsfpgkim1x.jpg.html)
https://static1.pt-content.com/images/pt/2016/12/IMG_1264_zpskthewjl1-1.jpg (http://s1060.photobucket.com/user/340cuda/media/IMG_1264_zpskthewjl1.jpg.html)
BlackdogNY
12-13-2016, 02:43 PM
That was my though process as well...any issues you have encountered??
B&G
HarleyR
12-13-2016, 06:38 PM
I'd say the location pictured is great... once you get stuff mounted look for used NASCAR stainless hardlines rather than running 10 feet of braided line.
71RS/SS396
12-16-2016, 03:40 AM
I would increase the size of the lines if you move it to the rear of the car, you're going to lose flow due to friction. I would use -16/1" hard line to cover most of the distance.
