View Full Version : A Body Brake Upgrade?
GBodyGMachine
11-15-2005, 06:26 PM
Looking for a cheaper way to do an upgrade on a 69 A Body Skylark.
I am looking at useing the B body spindle and tubular control arms.
Where can I get this stuff?
JEff
Marcus SC&C
11-15-2005, 07:18 PM
STOP,and do some research on it before you do the B swap. It does give you decent disc brakes. It also improves the camber curves. BUT it`s very detrimental to the steering geometry. It roughly doubles the stock bumpsteer (which is already poor),messes up the ackerman and slows the steering ratio noticably. You`d be better off putting together a low buck 12"/PBR brake setup with parts from a `98+ Z-28 or TA. MUCH better brakes and no steering issues. If you want to improve the suspension and steering geometry with the stock spindles we can help you with that. ;) Marcus SC&C
gchandler
11-15-2005, 10:14 PM
I run a b-body spindle and feel that it was a dramatic improvement over stock. I believe that with careful setup you can have a very workable setup with tall spindles.
What have I done?
Quicker steering box
Lower Car
Alignment
new upper arms
No it is not as simple as just swap in the spindles, but what ever is that simple.
GBodyGMachine
11-16-2005, 03:03 AM
What parts will I need to do the 98+ upgrade?
Jeff
Elusive R
11-17-2005, 07:28 AM
I did the B-body swap as well and I put in a Howe adjustable centerlink so bumpsteer is not an issue. Just another option. I, like Geoff, am very happy with my swap.
Ryan
