View Full Version : Gen 5 Camaro wheels?
DreKoushRanada
11-29-2016, 09:47 AM
I will be taking my 1970 Cutlass off the frame soon. I was wondering is I can use the 20" OEM Camaro wheels as low price rollers being that I will have 14" disc brakes?
Mr Nick
11-29-2016, 06:22 PM
Too much offset and the wrong bolt pattern. You'll need rather large adapters.
DreKoushRanada
11-29-2016, 06:26 PM
You are clutch as always. Thanks for the info. I might need to just wait until I have the suspension and brakes on it. I am sure that will further complicate things.
Mr Nick
12-02-2016, 04:34 PM
Good plan, if you are wanting to squeeze larger wheels/tires in there you should have your suspension and brakes sorted out first.
Kjames
12-02-2016, 06:25 PM
I'm confused, what is different with the bolt pattern?
DreKoushRanada
12-03-2016, 03:58 AM
Not much actually. 5x120 and our cars are 5x120.65. The will still technically match up. Similar to people running BMW wheels. These huge brakes I have are causing me to run bigger wheels.
Kjames
12-03-2016, 06:40 PM
So the 5 gen Camaro bolt pattern is 5x120 now and not 5x120.65 anymore
slimjim
12-04-2016, 06:10 AM
Correct, its an easier issue to overcome with using 5th gen brakes but the wheels will be a difficult fit
Mr Nick
12-04-2016, 02:16 PM
Will 18's fit with the brakes you have?
slimjim
12-05-2016, 04:04 AM
Short answer is yes, I have 18's up front, but there is less than 1/4" between the caliper to wheel so I can assume certain 18's may have trouble.
DreKoushRanada
12-05-2016, 11:38 AM
It would be nice if they can. The brakes are off the 5th gen SS Camaros. The frame should be put together by next week hopefully. I want to put something on them until I get the set I want.
DreKoushRanada
12-05-2016, 01:20 PM
