Shawn01754
11-27-2016, 08:18 AM
Well, with the lack of response from some vendors on campus & tales of belly up, out of businesses... I've narrowed my selection to a budget friendly rejoined partnership purchase with Summit Racing. I've heard and seen some negative feed back about CCP, but with summit at there back, I'm going for it.
https://m.summitracing.com/parts/clp-6474swbkstc5/none/images And on sale to boot. What you all think?
andrewb70
11-27-2016, 08:53 AM
Check out kore3.com
Shawn01754
11-27-2016, 09:55 AM
Hi Andrew, thanks for the info. I'll check them out. I was reading a little about your build yesterday and your car is awesome. It's actually inspirational.
Check out kore3.com
Ok I found this KORE3 GM 10/12-Bolt Application Chart
Year Make Model Notes
1964-1979 Buick Gran Sport, Skylark, Sommerset Regal, Special 1, 2, 3, 4
1973-1977 Buick GNX, Grand National, Regal 1, 2, 3, 4
1962-1979 Chevrolet Chevy II, Nova 1, 2, 3, 4
1964-1977 Chevrolet Chevelle, El Camino, Laguna, Malibu 1, 2, 3, 4
1967-1981 Chevrolet Camaro 1, 2, 3, 4
1968-1977 Chevrolet Monte Carlo 1, 2, 3, 4
1991-2002 GM S-Series Truck/SUV 1, 2, 3, 4
1964-1977 Pontiac GTO, Lemans 1, 2, 3, 4
1967-1981 Pontiac Firebird, Trans Am 1, 2, 3, 4
1973-1977 Pontiac Grand Prix 1, 2, 3, 4
1967-1977 Oldsmobile 442, Cutlass 1, 2, 3, 4
This kit includes the parking brake compatible brackets but none of the parking brake components.
This kit is compatible with C-clip axles only.
Axle flanges may need to be machined to be less than ø5.9" outside diameter to properly mate with rotors. Most axle shafts will need to be modified.
Minimum ø17" wheels are recommended, however not all ø17" wheels will fit. Verify wheel fitment prior to ordering using the appropriate KORE3 fitment template. Wheel fitment is the buyer's responsibilty. Please contact us if you have any questions regarding your specific application or the proper use of the templates.
Does the olds 442 rear end have c clips? http://www.supercarsunlimited.com/info/tech/diff_id/diff_id.htm And I believe not, does that mean this kit won't work?
Mr Nick
11-27-2016, 06:55 PM
I have a factory Type-O rear end, they are bolt in axles and do not have C-clips. I have KORE3 C5 brakes front and rear, call or email Tobin. He will get you set up.
968ls1
11-30-2016, 08:04 PM
I have a set of C5 Calipers $150.00 plus the ride if you need some.
Shawn01754
11-30-2016, 08:16 PM
I bought the CCP c-5 kit with the steering knuckles, hubs, rotors and discs. I also picked up the rear C-5 calipers and rotors. I still need the rear bracket, shims and e brake hardware. kore 3 seems a little steep @ $730 for just the hardware, but it may be the safest bet. Looks like CCP uses mustang rears on there big brake kits & that's a no no on this car.
