Blown1932
11-23-2016, 06:46 PM
Howdy,
Been getting good info from the site so I figured I'd finally join :-)
Current driver: 71 El Camino - 383 (Trick flow heads, roller cam, RPM air gap, 11.4:1, etc...), 700r4 (built with Freakshow 3000 stall), some suspension upgrades (Front - DA coilovers, tube arms, tall spindles, hy boost, 12" brakes, 1.250 bar, quick ratio box, etc... Rear - adj upper and lower arms, adj bar, QA1 stocker star, 9" alu center, Detroit locker 4.11:1, disks, 3.5 alu shaft, etc..)
Only have a few hundred shakedown miles on the build, so far so good.
Current project: 69 Camaro (SS 350 4sp car, original engine long gone) - Just starting the sub frame work - LS3 525, SW headers, dirty dingo mounts, GMPP vette front drive accessories, T56, stock sub frame with Speedtech arms, Viking DA coilovers, 13" brakes, tall spindle, 1.250 bar, rack & pinion. Rear is a full float 9" alu center Detroit locker, 3.89:1 Body is on a dolly but I haven't touched it yet. We have had this one for 30 years (less than 100k on it), started as my wife's daily driver and we are looking forward to getting it back on the road but it will be a long haul.
So, thanks for the info and look forward to more learning opportunities.
