View Full Version : How long to install baer brakes at all 4 wheels?
67rsconvert
09-18-2004, 04:05 PM
Car is currently front disc with rear drum. How long of a job is it to convert at all 4 corners with baer setup? Wondering if I should take the time to do it or have it done.
thanks!
dennis68
09-18-2004, 05:01 PM
The process of converting at the wheels should onlt take anamatuer 4 hours or so, less depending on your degree of experience. The master cylinder/proportioning valve and any hard line modifications or replacement is a bit more time consuming. Again this depends on your level of experience. An advanced level shadetree or professional could do the whole swap with lines in a 8 hour day pretty easily.
67rsconvert
09-23-2004, 04:28 PM
Thanks for the reply. Does the baer kit come with everything needed or should I source anything before taking car in? Brake fluid aside.
