View Full Version : 69 Camaro trunk battery help!!!!??
sweet motion
11-22-2016, 11:36 PM
Can anyone recommend a battery for my trunk? It's a pro-touring car with lots of electrical demands. I like agm's but not fond of Optima batteries due to lots of negative feedback.:seizure:THANX for lookin at this!
DT69Cam
11-23-2016, 04:50 AM
What's wrong with Optima ? I have had one for 6 years trouble free. I'm going to install another one as well.:hmm:
Just my 2 cents, bought optima red top for my z06 vette, so it would not have issues with acid as battery sits over main electrical harnesses..... It blew up and acid everywhere, never had an issue before, or after with any regular battery in same car, I will never buy another.... Also after that any battery I have will be enclosed as it can cause a lot of damage... Just my experience.
dhutton
11-23-2016, 05:47 AM
I have read good things about Odyssey batteries and I'm going to try one in my 69.
Don
ctcz28
11-23-2016, 05:50 AM
I've had good luck with Sears Diehard AGM batteries. I've put them in 3 cars with no issues. AGM's are pricey, but worth it as there is no fluid sloshing around or leakage. A vented battery enclosure is not a bad idea, but I've never seen one.
parsonsj
11-23-2016, 06:54 AM
Keep the battery properly charged, and you'll have much better luck with all the batteries mentioned above. Nearly all batteries sold in this country are manufactured by Johnson Controls, including Optima and Sears. Odysseys are manufactured in Europe and Missouri by EnerSys.
hifi875
11-23-2016, 11:01 AM
odyssey
analyte
11-23-2016, 10:38 PM
Lightweight Odyssey PC925 in my car for two years now with zero issues. Very pleased with the product.
cpd004
11-24-2016, 05:34 AM
My vote is for XS Power.
minendrews68
11-24-2016, 09:15 AM
My son put a Optima on his truck, we'll see how it does in the long run. The only problem I've heard about the Optima's is that if you let them go completely dead they're bad. I don't think that's entirely true, it does take a special charger to bring them back up, but the place he bought his told him if it ever ran completely down to bring it back to them and they would charge it back up for him.
scogin918
12-13-2016, 03:48 AM
Just took my third Optima Redtop back to the store to have them check it out. Can't seem to recover it even with the parallel "trick". I may get a yellow top instead if I can't find an alternative. Only problem is I have the Detroit Speed bracket so I'm kind of married to the 34/78 style/size. Otherwise I would have tried something else 2 batteries ago.
ilikeike
12-13-2016, 07:44 AM
My 7 year old Odyssey that I used in my daily driver truck and then Camaro is getting weak after it's sits for a few days now. It's a $250 battery,and has been great. But I went with an Exide AGM in the Camaro trunk this time, $164 from Amazon,at my house the next day.
I'm pretty sure they are the same as the Sears DieHard Platinum AGM.
https://www.amazon.com/gp/product/B0083C6M9U/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
elwaupo
06-09-2019, 07:05 PM
I had one in m 69 Camaro for about 6-7 years, I wasn’t impressed with the CCAmps, left me stranded on a busy freeway one time and I dumped it. I always kept it charged and never overloaded it with a lot of electrical accessories.
Doug1
06-11-2019, 11:08 AM
This is related to the thread I have on dual AGM batteries. To get the value out of these batteries, since they cost more but can last longer, you have tighter tolerances than a flooded battery. Optimas need 14.4-14.8 at the battery.
Just 1 More
06-11-2019, 12:24 PM
https://static1.pt-content.com/images/pt/2019/06/40937974303_d15ac06a58_c-1.jpg (https://flic.kr/p/25nxPva)20190520_201547 (https://flic.kr/p/25nxPva) by F G (https://www.flickr.com/photos/153250783@N04/), on Flickr
Warthog5
06-12-2019, 07:18 PM
Parallel Trick? Whats that?
Has your charging system been investigated? What are the results?
Red Top's are Starting Batteries
Yellow Top's are Dual Purpose Start & Deep Cycle.
Blue Tops...... Marine There are Starting and there are Deep Cycle
Doug1
06-18-2019, 02:15 PM
The parallel trick is to use an old standard lead acid battery and to connect the charger to it, while connecting the AGM battery in parallel. It keeps the charger running where it would otherwise shut off. It brought back an AGM I had from way below 8 volts, when no other method, or charger, worked.
I agree the charging system is suspect. The charging voltage is CRITICAL on these batteries and must be measured at the battery.
Also, it there is significant parasitic loss, the batteries will be short lived if you don't keep an Optima charger/maintainer on them.
I listed all the info Optima sent me regarding their batteries. IT's worth a read. Page two of the thread has the Optima and Odyssey replies.
https://www.pro-touring.com/threads/131246-Dual-AGM-Battery-system/page2
