View Full Version : Ford 6R80 cooler manifold
Craig@Bowler
11-08-2016, 08:32 AM
If any of you are looking for a solution to convert from your factory rigid tube cooler lines to a braided flex line we have a conversion manifold to give you that option. This black anodized, billet aluminum manifold incorporates a dual o-ring seal on each port and installs with the same bolt that secures the factory lines. The two line attachment fittings are a -6 AN male to give you the option of attaching a straight, 90 or 45 degree line fitting depending on how you will be routing the lines. Priced at $95 each and can be paired with one of our stainless or black braided line kits.https://bowlertransmissions.com/c/150/transmission-cooler-line-kit-4l80-4r70w-aod-700r4-2004r-automatic-transmission-cooler-braided-line-steel-line-google-transmission-parts-hose-6-an-fittings
133893
133892
