View Full Version : 4L70E pulled from a 2007 Trailblazer SS
Mofoe73
11-07-2016, 06:32 PM
I bought a complete engine from a 2wd trailblazer SS (6.0L + 4l70e) with 70,000 miles on it. I am going w a T56 and do not need the transmission. Was working when pulled. Comes complete as shown in the pictures (engine is NOT for sale). Comes with torque converter and flywheel. GM says it's rated for 700 ft/ lbs. AS IS no warranty.Pick up only! 12 miles east of downtown Los Angeles. I will remove add once it sells.
Los Angeles Area.
91706 zip
Price is $600 firm.
133872133875133874133873133876
Mofoe73
11-21-2016, 10:22 AM
bump.
99socalfrc
11-26-2016, 11:09 AM
If you understand electronics and the LS series engines this transmission is gold.
It is maybe the only 4 speed auto that will work with the E38 or E67 ECM (the one most commonly mated to LS7 and LS3 engines). It has the input speed sensor circuit that earlier 4L60 types lack.
E38 and E67 computers typically mate with 6-speed autos which will require cutting the tunnel on most swap cars. This 4 speed though goes right in like butter.
This trans is also going to be stronger than the 4L60 and 4L65, it has 5 planetaries. So even as a rebuild core this trans is worth $500 easy.
In short, someone should buy this ASAP. (I already have the exact same one in my LS3 swapped 68 Camaro, and my 2006 Trailblazer SS that pushes 700 horsepower and runs 11.40's in the quarter mile)
spacepirate
11-26-2016, 07:17 PM
Sent PM
Mofoe73
11-28-2016, 06:32 PM
PM returned.
Question was asked if i have the wiring harness etc. I do have the OEM harness which im sure will be stripped off (im doing a t56) can someone confirm what needs to be removed or if it can even be removed off the old wiring harness? Im pretty sure one of the gray boxes on my harness controls the 4l70e
willieboy240
11-29-2016, 09:10 AM
Sent pm
Mofoe73
12-01-2016, 04:46 PM
PM responded too. Still available
willieboy240
12-01-2016, 06:43 PM
Sent you a pm asking what city are you in ?
Mofoe73
12-01-2016, 07:39 PM
Pls read the add
jjump59
12-02-2016, 06:07 AM
pm sent
Mofoe73
12-02-2016, 08:40 AM
PM's returned.
Mofoe73
12-12-2016, 09:51 AM
SOLD! SOLD! SOLD! to the gentlemen from AZ.
