View Full Version : Relay box for headlights, horn, fans
XLexusTech
10-28-2016, 05:24 PM
Looking for advice on a compact box for 5 relays.. would like to use std relays, looking for a bussed kit that would be nice and neat.
Trying to avoid the mini relays only because I have all the std relays already.. but I could be convinced otherwise..
the Hella kits are not bussed so I figure they are messy to wire..
The bussmann ones are slick but the only ones I found were for all mini relays.. What about take outs form the bone yard?
Any ideas considered..
thanks..
andrewb70
10-29-2016, 09:09 AM
I have some Delphi stuff banging around. PM me your email address and I can send you pictures. If you want something new, the Bussman boxes look very nice, but will use mini relays, just like the Delphi ones that I have.
BonzoHansen
10-29-2016, 07:20 PM
I think stielow used the bussman stuff on his last build. I was think about that, looking at the waytek site. But i saw AAW now offers a kit, and i think painless does too
XLexusTech
10-30-2016, 04:18 AM
Andrew will do thank you
XLexusTech
10-30-2016, 04:20 AM
They do for 2 relays that I can find they are basically 2 wired relays wth long leads for over 100 bucks ... no thanks :-)
BonzoHansen
10-30-2016, 05:20 AM
Which are you talking about?
gray86hach
10-30-2016, 06:44 AM
http://www.leashelectronics.com/Relay-Boards_c5.htm
70 Chevelle
10-31-2016, 03:51 PM
https://www.waytekwire.com/item/46345/Cooper-Bussmann-15303-5-2-4-Mini-Fuse-Panel-/
They are available bussed and non bussed. As a bonus they are compact
BonzoHansen
11-01-2016, 06:29 PM
Those are the ones i saw
H2Ogbodies
11-19-2016, 07:16 PM
Just grab an LT1 (or a V6) 4th gen underhood aux. fenderwell mounted relay/fuse box-compact, neat/tidy and will look factory....I use them all the time.
XLexusTech
11-19-2016, 07:44 PM
Looking online got a picture?
Motown 454
11-19-2016, 08:22 PM
Can the back be opened up to run the wires right from there instead of splicing if its been cut out?
H2Ogbodies
http://m.ebay.com/itm/93-97-Camaro-Z28-GM-3-4-V6-under-hood-fuse-relay-block-box-/222315113805?nav=SEARCH
Not mine but this gives you an idea-if you search a few auctions you'll see the lid/cover for it too. These are easy to find at a junkyard-they are mounted on the LH inner fender behind the core support. Very compact-they have a large stud to provide a bussed source for power and the fuses are bussed to each other-so wiring in fuse protected relay circuits is very easy to do. The lid/cover goes over it with a single screw down stem in the middle.
H2Ogbodies
11-19-2016, 08:26 PM
The individual bussed terminals can be bought through GM still for it too. I don't have the part numbers but I remember pricing them out to do a custom LSx install in a mid 80's Silverado for a customer once. He had a lot he wanted-electric fans, relay powered headlights w/delay off, nitrous/purge relays, ignition control and auto kill relays, etc. so this is the relay/fuse center I suggested.
Aficionado
11-21-2016, 06:06 PM
The control box for the plug'n'play LS3 crate motor is also an option. I think Mouser has all the parts and terminals: I redid one with two added relays for a total of five, IIRC. It's a standard GM part that was used on the Eacalade, with bussed power and lots of slots for both mini and maxi fuses.
If you're interested I can find the part numbers.
HotWired
11-21-2016, 06:25 PM
yes please
astroracer
11-22-2016, 09:05 AM
I use the Project Boxes from Radio Shack. Don't know how available they are any more... Here is a link to another supplier for plastic boxes. They also have some aluminum and other styles so look around in their site.
https://www.polycase.com/general-use-enclosures
here are a couple I have put in my truck and the van I am building. The one in the truck was painted body color and it disappears into the fender. The one for the van will get the same treatment.
https://static1.pt-content.com/images/pt/2016/11/100_1188vi-1.jpg
This is the van box. This has a bunch of relays in it now. Had to fab the bracket to hang it from. All of the wires pass thru the back, thru the sq. hole in the bracket and out to the fans, NS Switch and B/U Lights.
https://static1.pt-content.com/images/pt/2015/08/MVC023Fvi-1.jpg
https://static1.pt-content.com/images/pt/2016/11/MVC022Fvi-1.jpg
H2Ogbodies
11-22-2016, 12:05 PM
Cool but it's a lot handier to have bussed battery leads and spots for mini or maxi fuse AND relay bases too if a factory look is the objective.
voodoo51
12-16-2016, 06:27 PM
I am using this one on my camaro..Ebay135093135094135095
