View Full Version : 69 Camaro power bullet style mirrors
AB69Z
10-26-2016, 09:46 AM
Does anyone make a kit for these or complete units?
i think I remember being told that the GM bullet mirrors of a different car fit the 69 Camaro without modification
pittpens24
10-27-2016, 02:54 AM
You can buy OER mirrors off of a '71 to '78 camaro I believe which will have a manual remote drivers mirror and manual passenger. These will fit your camaro but you will have to drill mounting holes as they have a different stance than original. If you want power they are a little hard to come by but still available. The Vette's had em in like '81 or '82. Good luck my friend.
AB69Z
04-28-2019, 07:04 AM
Question : if I don't want to cut into my custom door panels to install the drivers mirror support what can I do with the remote cable?
I don't think I can cut it off because the mirror will loose tension and go out of its adjusted position
If I curl it up and tie it up inside of the door panel I believe how it's placed will also effect the mirror tension.
Would I like to put in power units , yes! But I haven't located anything when I was looking
morrisclassic
04-28-2019, 05:00 PM
Put a set of Morris Classic Clear Shot mirrors on your
Camaro that look close to original ,our Patented
design Eliminates the Passenger Side Blind Spot. Our
mirrors will stay in their adjusted position.You can adjust
the tension on the ball & socket with 2 recessed screws
if ever needed. 3 yr warranty. Search on this forum for
reviews.
Billy
pittpens24
04-29-2019, 02:17 AM
Can't cut it off and you most likely cannot bury it as it will catch the window track or mechanism when rolling the window up and down. Just cut it into your door panel or go with a full manual set
