View Full Version : 2013 camaro clutch safety switch delete
timopajala
10-22-2016, 07:25 AM
Hi, im working on this and need to know how to delete the clutch safety switch. The engine is going in my 1967 camaro. It has 3 wires going in the plug and i think they work like tps sensor so theres potentio meter or something like that in the switch. Any help would be really nice because i have no idea witch way to go on.
timopajala
10-22-2016, 08:22 AM
can this be bypassed by skipping these switches and running straight wire to starter? It will crank but will it start?will it set a fault code after that? The clutch switch sends 0-5volts to ecm and the ecm sees from that in what position the clutch is currently.
just read from some other post that it has relearn process and will set code etc. Just might have to work the switch to my pedal somehow. Or i disassemble the switch and hook it so that i can push it by hand when i start etc. Damn that is not so easy thing to work with. If someone knows how to bypass this thing would be really nice!
