garvir
10-13-2016, 02:31 PM
i had no luck with setting toe off the tires, so i came up with this tool that i use bungee cords to hook to rims, take about five minutes for me to hook it up by myself. use the same tape measures so they will be the same weight, i usually set both at 82" so they both hang the same, will vary on how you make your tool. while you are at it cheek you rims for runout in case one of them is bent, bad numbers if you have a bent rim. living in michigan i check my often, we have big pot holes. use level on both sides, they only cost a couple dollars, you have to be level. all four tires are sitting on 6x6s so i have the same height.
my next article will show how i use lasers attached to the same tool to check my ackermann, cost me about 50.00. to buy the real tool runs about 500.00, i am retired and do not have a lot of money.133056133057133058133059
