View Full Version : Value of ls9 engine
catz
10-08-2016, 04:36 PM
I have a 2010 zr1 ls9 motor complete with all drive accessory oil tank plus lines and computer 12,500 miles was planning a swap but having second thoughts thanks
raustinss
10-09-2016, 03:52 AM
Depends on location to some extent
Bill Howell
10-12-2016, 05:02 PM
Someone has one currently in the for sale section for $10,500. Claims zero mile take out.
andrewb70
10-12-2016, 05:44 PM
I believe that was a LSA engine.
The LS9 is a bit of a pain for swaps because it has the dry sump pan which doesn't work too well with stock type frames. I'd say $15k, but that is a pure guess.
raustinss
10-12-2016, 05:51 PM
I'd agree Andrew... again depends on the area to some extent... northern states and Canada have a lot less to pick from then the fellas in the south
catz
10-13-2016, 05:57 AM
Thanks guys its in the north east but not many of these for sale,I could not even find 1 for sale to compare it to. the dry sump can be converted to wet fairly easy, but i was going to have a tank tank made to fit under the fender on my 69 camaro and cut the coner of the cowl off plenty of room. I think the next step is to move it to the for sale section I have all parts including the intrcooler system gas pedal hoses coolant lines and harness from car thanks again. as far as the lsa completly different motor ls9 has titanium rods,titanium valves,oil squirters for bottom of pistons ,steel crank,special casting alloy for block and heads,special casting process and I,m sure more stuff.
daryld
02-14-2021, 01:12 PM
I know this post is a few years old but did you ever sell the LS9?
