View Full Version : Lsx Concepts CTS-V Brakes
the owl
10-08-2016, 01:44 PM
Hi All, this post is very delayed as I have been running this setup for a few months now but I did want to post and thank Lsx concepts for an amazing product, excellent work, and incredible customer service as we went through some headache getting the rear to work since I have a 12 bolt with ford ends. In the end everything fit perfect and I can't say enough great things about Lsx Concepts.
The calipers are from a 2011 cts-v and rotors were made by adams rotors (15 inch fronts and 14.4 inch rears)
Enough talk, onto the pics.
https://static1.pt-content.com/images/pt/2016/10/20160911_085504_zpsjse0gm1t-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20160911_085504_zpsjse0gm1t.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20161008_151151_zpsm7ojtzog-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20161008_151151_zpsm7ojtzog.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20161008_151218_zpsbradnazq-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20161008_151218_zpsbradnazq.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20161008_151129_zpsrjcsafyd-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20161008_151129_zpsrjcsafyd.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20160911_085601_zpsbv3ocepf-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20160911_085601_zpsbv3ocepf.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20161008_151233_zpszzdqegab-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20161008_151233_zpszzdqegab.jpg.html)
https://static1.pt-content.com/images/pt/2016/10/20161008_151412_zpsopnbyhnb-1.jpg (http://s21.photobucket.com/user/subiedude03/media/Mobile%20Uploads/20161008_151412_zpsopnbyhnb.jpg.html)
ClosNova805
10-08-2016, 03:29 PM
Man that looks killer
rocketrod
10-08-2016, 04:52 PM
Looks great. On the front are you running stock spindles? Do you know if they make an adapter to ru n the brakes with afx spindles?
the owl
10-08-2016, 06:25 PM
I am running ride tech spindles with wildwood hubs
slimjim
10-09-2016, 01:01 PM
Looks awesome, I have the LSX concepts brackets with the same spindle and hub setup. I was really happy with the fitment. I don't believe they will work with AFX spindles
130fe
10-09-2016, 04:10 PM
Looks great! What size MC did you use? What are the specs on the wheels and what size hub pads did they have?
adamsrotors
10-09-2016, 04:41 PM
thanks for posting the pics. that's a killer set-up!
we've been doing a ton of these CTS-V rotors for diff. conversions...feel free to visit our site (www.adamsrotors.com) or email (
[email protected]) us any questions!
the owl
10-09-2016, 05:15 PM
Thanks Adam! You guys definitely know what your doing, these rotors are awesome.
As for the MC and pad height, I'll have to go back and track the numbers down. I bought the master years ago when I was on a wildwood setup. The pad height was whatever weld considered "high pad height" I'll have to track those numbers down as its been a while.
I also believe there is a different vendor that makes this setup for afx and different hubs, it was on a post here somewhere.
ChevelleNV
10-11-2016, 06:59 PM
Thanks for the great review on our brackets Tom, glad to see everything went together and fit like its supposed to even though we had to make a custom one off set of brackets without test fitting. what wheels specs did you get to fit your combo (offset/size)?
the owl
10-11-2016, 07:11 PM
The fronts are 18x9 with 6" bs and the rears are 18x11 with 6.6" bs. Specifically, these weld wheels have a bunch of room for brakes. I had xxr 526's before that would not fit (not surprising as they were cast wheels)
ChevelleNV
10-11-2016, 07:12 PM
Love your car....nice job
the owl
10-11-2016, 07:15 PM
Thanks man, it's people like you that make it possible for us garage built guys with simple hand tools.
wyattroa
03-17-2017, 01:29 PM
Did you run into any problems mounting these up. I am debating on buying these brakes for my 66 chevelle. I'll also be mounting them on ridetech spindles. Any suggestions or advice would be great.
wyattroa
03-17-2017, 04:22 PM
Also, what did you do for emergency brakes?
ChevelleNV
03-17-2017, 04:56 PM
Our Ford 9 Inch Rear end kit for the 5Gen Brakes uses the factory GM emergency brakes from the donor car with some fairly easy modifications.
70Uglybird
03-17-2017, 09:35 PM
Will these work with standard brembo? I just upgrade my 2011 SS to zl1 brakes and have a low miles stock ss setup...
ChevelleNV
03-17-2017, 09:42 PM
As long as they are the Gen5 SS Brembo's yes...
DreKoushRanada
03-17-2017, 10:01 PM
Oh no! I have the XXR 526 BNIB. I have the 20" version of them for my gen 5 conversion. Do you think the size I picked will fit?
oleyeller
03-18-2017, 04:54 AM
Looks great, do you remember how much you narrowed the rear end? Just comparing backspace numbers and was curious how narrow yours was.
the owl
03-19-2017, 10:31 AM
Ridetech spindles will work, it is what I am running.
As for the 20"xxrs it might fit. It wasn't the caliper overhang it was the thickness of the wheel for a 18".
My rears is narrowed 2" total..... 1 on each side.
DreKoushRanada
03-25-2017, 06:33 AM
Thank you for that info. I did my rear end like yours. Narrowed 1" on each side.
Buryingthesun
06-01-2017, 03:26 AM
CTSV Front calipers WILL NOT work on the ATS/AFX spindles, there is also not enough room for adapter brackets to make them fit due to webbing on both the calipers and the spindles. I tried and failed, I used a 2015 Camaro SS brembo rotor and the CTSV front and these are my results. After taking measurements it looks like you would need a 16" rotor to use these calipers and thats just silly. I also had to have the hub bore machined out just to fit the rotor on the ATS spindles.
the owl
06-01-2017, 05:59 AM
Just as an outsider looking in I noticed 2 things:
1) I believe the issue you are having is the brackets are made for V2 (2009-2014 CTS-V) brakes and you have a V1 (2004-2007 CTS-V) Caliper in the picture?
2) The rotors for a V2 are roughly 15.5" rotors which may possibly solve your problem. Off the top of my head 2015 Camaro rotors are only 14".
I hope this helps!
