View Full Version : Heater and Ac hose routing
fishface
10-05-2016, 11:47 AM
Hi, I am finally getting to the point of routing these hoses and looking for the cleanest look. This is on my 69 Camaro with the Concept One accy drive which has Ac ports low on the compressor. I have seen the hoses clamped on top of the wheel well on the engine side as well as in the opening between fender and top of wheel well. Any pros/cons to running them there?? Also, what is the typical routing for the heater hoses?? Any help appreciated.
Dark Pursuit
10-05-2016, 12:10 PM
Your hose routing will also depend upon your connections at firewall Do you have factory or aftermarket a/c ? Are you doing battery relocation or factory battery tray ?
fishface
10-05-2016, 01:40 PM
Hi, this is with the Classic Auto Air Ac and I am using the battery tray
Dark Pursuit
10-05-2016, 02:04 PM
Classic Air a/c connections at the firewall ar a bit inboard to put lines into your fender wells. Also stock battery location makes for too tight of a turn to allow for your a/c filler fittings. Original hose routing on inner fender is probably the route that you will have to use.
fishface
10-05-2016, 02:11 PM
Ok, thanks for the info. Do you have any recommendations on the heater hoses??
